"SUB or FUNCTION cannot be nested"...error message in Propbasic
denno
in Propeller 1
Having a tough time figuring out what the above means. I have a GOSUB in a do/loop, but the respective SUB ROUTINE with the RETURN is outside the DO/LOOP. It is not "nested", as far as I can see...
DEVICE P8X32A, XTAL1, PLL8X XIN 5_000_000 STACK 100 '========CONSTANTS============ baud2 CON "T115200" HMC6352_READ CON $43 HMC6352_WRITE CON $42 GET_HEADING_command CON $41 '========PIN ASSIGNMENTS======== 'Assignments of pin go in each COG that is using that pin.. HMC6352_data PIN 1 HMC6352_clk PIN 2 '============CODE=============== '================VARIABLES================== I2C_DATA VAR LONG I2C_LSB VAR LONG rawHeading VAR LONG HMC6352 TASK PROGRAM Start 'this is running in COG 0 Start: DO I2C_Start SUB I2C_Write SUB I2C_Stop SUB I2C_ACK SUB I2C_Read SUB I2C_NACK SUB '''''''''''''''''''''''''''''''''''HMC6352: ''''''''''''''''''''''''''''''''''first read GOSUB I2C_Start ' Start communications on the I2C buss I2C_DATA = HMC6352_WRITE GOSUB I2C_Write ' Address the HMC6352 in write mode I2C_DATA = GET_HEADING_command GOSUB I2C_Write ' Send the get rawHeading command GOSUB I2C_Stop ' End communications on the I2C buss PAUSE 10 GOSUB I2C_Start ' Start communications on the I2C buss I2C_DATA = HMC6352_READ GOSUB I2C_Write ' Address the HMC6352 in read mode PAUSE 10 ' Give the HMC6352 time to calculate the rawHeading GOSUB I2C_Read rawHeading = I2C_DATA 'HIGHBYTE Read in the high byte GOSUB I2C_ACK GOSUB I2C_Read rawHeading = I2C_DATA 'LOWBYTE Read in the low byte GOSUB I2C_NACK GOSUB I2C_Stop ' End communications on the I2C buss rawHeading = rawHeading / 10 'whole degrees LOOP '=======================SUB ROUTINES======================== SUB I2C_Start HMC6352_data = 0 ' Pull HMC6352_data low HMC6352_clk = 0 ' Pull HMC6352_clk low RETURN ' SUB I2C_Stop HMC6352_data = 0 ' Pull HMC6352_data low HMC6352_clk = 1 ' Let HMC6352_clk float high HMC6352_data = 1 ' Let HMC6352_data float high RETURN ' SUB I2C_ACK HMC6352_data = 0 ' Pull HMC6352_data low HMC6352_clk = 1 ' Let HMC6352_clk float high HMC6352_clk = 0 ' Pull HMC6352_clk low HMC6352_data = 1 ' Let HMC6352_data float high RETURN ' SUB I2C_NACK HMC6352_data = 1 ' Let HMC6352_data float high HMC6352_clk = 1 ' Let HMC6352_clk float high HMC6352_clk = 0 ' Pull HMC6352_clk low RETURN ' SUB I2C_Read SHIFTIN HMC6352_data, HMC6352_clk, MSBPRE, [I2C_DATA] ' Read in 8 bits, MSB first RETURN ' SUB I2C_Write I2C_LSB = I2C_DATA.BIT0 ' Store the status of the LSB I2C_DATA = I2C_DATA / 2 SHIFTOUT HMC6352_data, HMC6352_clk, MSBFIRST, [I2C_DATA\7] ' Write out the first 7 bits, MSB first IF I2C_LSB THEN INPUT HMC6352_data ELSE LOW HMC6352_data ' Write the 8th bit INPUT HMC6352_clk ' Using an open collector output LOW HMC6352_clk INPUT HMC6352_data ' Leave HMC6352_data as an input INPUT HMC6352_clk ' Ignore the ACK bit LOW HMC6352_clk RETURN ENDTASK HMC6352
Bean
DenO
You do ENDTASK without even making a TASK ?
You need to move the SUB defines before the PROGRAM line (before any code).
You don't need GOSUB to call a SUB, just put the name.
Why running at 40MHz instead of 80MHz ?
You don't need STACK if not using LMM mode ?
I have no idea if this will work, but something like this is formed right.
P.S. You will probably need to put a delay every time you set a pin because the Propeller is too fast.
Bean
Has anyone written any code for the above, that they would like to share with a "newbee", for my learning experience.?
I appreciate your time...and I have been using the FLIP, with other programs in PropBasic, and what a great "all in one processor". Hope it will become as popular at the Basic Stamp...was.
DennO
