Propeller P1 Stacker for breadboards — Parallax Forums
P1 QFP is to nice looking to hide underneath.
The idea is that the dip sockets machined pins rim works as smt pads.
Most pins are brought out, some have additional features.
P12 DAC/REF
P13 8bit 500K spi ADC
P14 8bit 500K spi ADC
P15 I2C clk fastmode+ (2.2K pullup)
P16 I2C data fastmode+ (2.2K pullup)
P17 SPI clk (2.2K pullup)
P18 SPI mosi (2.2K pullup)
P19 SPI miso (100K pullup)
P20 SPI CSn_0 internal to ADC (100K pullup)
P21 SPI CSn_1 (100K pullup)
P22 SPI CSn_2 (100K pullup)
P29 LED shared with internal eeprom sda.
The ADC is the cheapest 2channel at $1, they probably have drop in replacement for 12bit and/or 1MHZ for a little more.
https://www.mouser.com/datasheet/2/256/MAX11661-MAX11666-101409.pdf
I'm sending away for 9 pcb (0.8mm 2layer) today, 100's probably three weeks later for ~$25.
Free China CP2102 "Prop plug" included.
696 x 533 - 111K
367 x 306 - 158K
  • This looks cool. I like the machined pins that I assume will be kinder to breadboard holes than the pins used on the Flip.
  • tonyp12tonyp12 Posts: 1,950
    edited 2018-07-22 19:01
    I always disliked pin headers, time consuming to solder and pins are to big that they ruin breadboards.
    Machined pins at 0.5mm is the way to go, using a dip socket I also get a free carrier.
    And female to male unlimited stacking!
    Attached is a 3D PDF if you want a fly through.
  • Oh, VERY cool!
    I assume that these will be for sale? If so, put me down for a couple. :cool:
  • jmgjmg Posts: 15,145
    edited 2018-07-22 20:45
    tonyp12 wrote: »
    So do you reflow this, onto the top of the machine-pin-sockets ? I've thought about that in the past, but never set up to actually try it...
    Would a castellated/plated edge make that easier to inspect / repair ?
    We have used standard DIP sockets, stacked after the machine pins, as a lower cost sacrifice component, as the machine pins can be prone to snapping off...
    tonyp12 wrote: »
    Did you look at the ~25c MCUs like N76E003AQ20 ( or N76E003AT20) ? - 8 Ch 12b ADC with i2c
    edited 2018-07-22 22:04
    There is not much of a rim at 1/8mm, see picture below.
    But still a lot of surface and 28pads holding it down at the same time and some solder should seep up the wall too.
    I have a e 80% circle solder past on that surface area, so the plan it goes in the oven with the other parts.
    As pcb is exactly the same size as carrier, it is easy to align up.
    I don't' think I will not dabble with firmware on cheap mcu thought they actually cost less than stand alone adc.
    This 12bit 2MHz is a drop in replacement for deluxe version of Stacker:
    https://datasheets.maximintegrated.com/en/ds/MAX11102-MAX11117.pdf
    815 x 688 - 48K
  • Is there something wrong with the pin labeling? I count 14 pins per side, but there appear to be 15 labels per side?
  • What am I missing?
    You have 14 pins down the left side of the socket but there are 15 PIN numbers silkscreened. It looks like P7 isn't connected, or are two pins tied together on the bottom layer?
    Have you considered a DIP32? That could give you external access to 4 more pins. How many would that leave without an internal or external function?
    Or even a DIP40 with as close to the original Propeller pinout as possible, while keeping your additional parts?
    edited 2018-07-23 00:33
    Thanks for catching that mistake, P7 and P8 was connected to same pad
    P11 is now internal only, it is used with P12 for a 2bit resistor-DAC for ADC-REF, better than noisy PDM.
    I also added pads for optional 3.3V LDO, though you're suppose to supply 5V and 3.3V externally
    but if the need comes up where you only have 5V.
    926 x 573 - 131K
    tonyp12 wrote: »
    Sounds good, I guess you could also 'cut away' two corner pins, if you wanted to tack solder that to locate it ?
    tonyp12 wrote: »
    Yes, it's somewhat nuts that small MCUs cost (much) less than ADCs/DACs now !
    If your focus is on better analog (which seems a good idea to differentiate), you can get a 3x3mm MCU with 12 x 12b ADC and 2 x 12b DAC for 67c/1k
    That specs 1Msps/10b and 350ksps/12b ADC - getting close to that deluxe version ...
    The MCU also comes in 4x4 QFN and TQFP32, for a few more cents, and I might try to fit the TQFP32 for lazy manufacturing tolerance.
    This MCU can also output a 2% 49MHz/2N sysclk, to cover 4.9MHz, 6.125MHz, and it can manage DTR reset pulse, so the BOM could slash if you wanted it to...
    If using that, I'd add an Oscillator footprint, to allow the 'deluxe' variant to have precise clocking option.
  • Be sure to test those sockets on an actual breadboard. It's surprising how long the pins have to be to a make a secure connection. Pins designed for soldering to a PCB probably won't cut it.
    edited 2018-07-23 02:20
    I'm hoping 3.17mm is enough.
    I think it is way longer than needed if it's a 1.6mm pcb board it's intended for?
    282 x 170 - 12K
  • I have some sockets that fit that spec, so I tried one in a solderless breadboard. It fits and seems to make a good connection without popping out, but only because the pin's wider shoulder partly nests in the square recess before the hole gets narrow.
    How much margin does that have ?
    I find an Asian drawing that specs 7.5-4.7 = 2.8 mm pin length, so is slightly shorter. I also found a web comment re breadboards that 0.1" sq pins were too short, but 0.126 (3.200 mm) was ok
    edited 2018-07-23 03:00
    Not much. If I install the socket so that the bottoms of the shoulders are level with the top of the breadboard, rather than seating in the recesses, it tends to pop out. That's a difference of 1.4mm (or less, depending on the breadboard).
    I tried it in two different styles of breadboard, pushing it in as far as I could. In one with smaller recesses, the shoulders did not fit all the way into them, but the socket still seemed to seat firmly.
  • tonyp12 wrote: »
    YES, TONY!!! Someone gets it! Machined pins are always cheaper than replacing a wrecked breadboard. I have happily paid the difference for these many times. It's also why my favorite EVK has generally been from TI because they include these and if I need more, there is always digikey or Avent or Mouser.
  • Really nice design, Tony
    There is a series called Oupiin 8004 that has a greater stack height if required. On those, the actual fine pin length is more like 4 than 2.75mm indicated on drawing.
    tonyp12 wrote: »
    3v3 regulator is a good idea. Did you look at LDL1117 ? - that is SOT223, low dropout, and accepts 9V too.
    tonyp12 wrote: »
    Thinking about this some more, skipping a pin could be a pain, eg for someone wanting to connect to a Parallel LCD, 16b Data bus ?
    Can the upper-pins, (not connected) be used for things like ADC-REF.
    ( Note with using an MCU ADC, the VREF is included).
    edited 2018-07-23 23:12
    Any of these LDO's will work:
    https://www.mouser.com/Semiconductors/Power-Management-ICs/Voltage-Regulators-Voltage-Controllers/LDO-Voltage-Regulators/_/N-5cgacZ1yzvvqx?P=1z0wa2eZ1z0z33q&Ns=Pricing|0
    P11 and P12 are merged as R/R2 so there is as way to decode back if you really want it, but a 0.1uf is attached so slower response.
    Running out of space on a 2layer board to pick and choose what pin goes where.
    After the first 9board for testing I maybe start from scratch again and make sure P0-P15 are pure gpio, but who want to waste 16pins on data bus, when there is 1MHz I2C/QSPI.
    edited 2018-07-24 00:01
    tonyp12 wrote: »
    Main use I was thinking of, was LCD displays, where parallel bus is always fastest.
    If you do a respin, then if you can fit in a QFN24(3x3) or QFN32(4x4) or TFP32 MCU, I can run up some i2c-ADC etc code.
    Your ADC choices are 12 x 12 or 12 x 14 bit, and you can even have 2 or 4 12b DACs, which makes for a nice higher performance analog solution.
    Also possible on this MCU is a 5MHz or 6.25MHz user choice of CLKout for Prop clock (removes the XTAL).
    AJL wrote: »
    Pin count is an interesting question.
    Checking lcsc.com, I can find 32 pin machine sockets DS1001-01-32BT1WSF6S-JKB for 100+ $0.2965, but no 28 or 40 pin ones. To me, 32 pins is better than 28.
    If this jumped to 40 pins, then the logical step is to clone the FLiP pinout - but it seems to make more sense to not duplicate FLiP, but rather expand into areas FLiP does not cover ?
  • Success, why have the world been using 0.64mm pin headers for the last decade?
    First test did not work, but now all pins make contact just say that is my trade secret :)
    Stackable, It did need some harder pressure to be convinced to stay down.
    Swiss made preci-dip sockets.
    3.5mm length would been perfect, but 3.17mm is snug.
    I will announce a paypal link next week for the 8 hand-made founders edition.
    64K eeprom,
    10bit adc dual channel with 3.3v, 2.2v & 1.1v selectable reference (e.g the 1000 step granularity can be between 0v-1v)
    911 x 885 - 264K
    883 x 923 - 268K
    769 x 816 - 222K
    edited 2018-10-10 21:47
    tonyp12 wrote: »
    from a P2 thread..
    Would that soldering work on these machine screw sockets ?
    https://www.mill-max.com/assets/pdfs/090.pdf
    The P2 talk wandered onto DIP modules & special packages to get that.
    However, there are standard 0.9" DIP 64 sockets (from 68000 legacy tooling ?) that will (just) fit the standard P2 package.
    Digikey also shows 0.9" 50 pin, but that is probably far too niche.
    Overall DIP64 length is larger than it really has to be, to fit a P2 support, but it will help with cooling and save a heatsink ;)
    Using PcbNew to guide price corners, it seems 4 layers, 0.25mm via will allow TQFP100 to fit in the tramlines ok.
    Attached is a routing /physical rough proof of concept for a FLiP_P2_64P
    Addit: as well as the 0.9" sockets, ebay shows strips too...
    50Pcs Single Row 40Pin 2.54mm Round Female Pin Header gold plated machined $10.68
    50Pcs Pin Header Single Row 40Pin 2.54MM Round Male Gold Plated Machined $20.35
    746 x 358 - 38K
  • tonyp12: Very clever concept with the sockets, I like it. Theoretically, you could stack an endless amount of add-on boards if they had openings for all pins? Does your SID board use all 28 pins on its socket? Or did you remove some pins?
