Spurius characters occationally
The weather program that I've been working on for a while is nearing completion, thanks to a lot of help from this forum!
Sometimes weird characters show up after running it. If left for hours it also sometimes locks up. I don't know how to figure this out. There must be some anomaly somewhere.
How do I check for this?
There are also a few other things that need completing.
It's a long program, but if anyone has time on their hands and could point me to some bad code, that would be appreciated?
OBJ
    vga:    "VGACOLOR_320x240_CURSOR"  ' VGA Driver             need 2 Cog's
    i2c  :   "I2C pasm driver v1.8od"
PUB main
    cognew(windSpeed,@stack)
    cognew(RTCcog,@Rtcstack)
    init
    initScreen
    ms := 0
    repeat
        dira[16]~~
        Winput:=I2C.readByte(MCP,GPIOA)      ' wind direction
        dir:=winput
        updateDir
        waitcnt((clkfreq / 1000) * 1 + cnt)   ' wait 1 ms
            'get_measurements                 '' reads temperature and pressure into UT and UP
        I2C.writeByte(BMP,CONTROL,TEMP)      ' start a temperature measurement
        waitcnt(cnt + clkfreq / 10000 * 45)  ' wait 4.5ms
        UT := I2C.readWordB(BMP,ADC)         ' read temperature
        I2C.writeByte(BMP,CONTROL,PRESSURE)  ' start a pressure measurement - 0 oversampling
        UP := I2C.readWordB(BMP,ADC)         ' read pressure
        convert_measurements
        PSI:=(p-1280)/(32)
        updateSpeed
        waitcnt(clkfreq/2+cnt)
        ms++
        str(15,27, $0F, $00,string("reset at 0"))
        decxy(27, 27, $08, $00, (120 - ms))
        if   ms=>120    'works out to be every 71 seconds
          ms := 0        'clear and restart counter
          gust := 0      'clear gusts
        updatetime
        if (ms==40) OR (ms==80) OR (ms==2)
          updateTemp
          updateBarom
          updateHDC
          outa[16]~~
          waitcnt(clkfreq + cnt)  'adds a second to the ms countdown
          outa[16]~
PRI updateSpeed    '
    'decxy(11, 3, $08, $00, speed)
    updategusts
    updateMax
PRI  updateGusts
  if  speed > gust
    gust:= speed
  if  ms==120
      gust:=0
  decxy(29,3,$0B,$00,gust)
PRI  updateMax
    if  speed > maxWind
      maxWind := speed
      decxy(11,5,$0B,$00,maxWind)
       hex(timbuf[2],2)
       str(19, 5, $0B, $00,@nstr)
       str(21, 5, $0B, $00, string(":"))
       hex(timbuf[1],2)
       str(22, 5, $0B, $00,@nstr)
PRI updateTime   'this is time in lower right corner
    hex(timbuf[2],2)                   'convert hours to string stored at nstr
    str(31, 25, $0B, $00,@nstr)
    str(33, 25, $0B, $00, string(":"))
    hex(timbuf[1],2)
    str(34, 25, $0B, $00,@nstr)
    str(36, 25, $0B, $00, string(":"))
    hex(timbuf[0],2)
    str(37, 25, $0B, $00,@nstr)
PRI updateTemp   'this is inside temp from baro sensor
    decxy(10, 9, $0A, $00, (T * 9 / 5 + 320)/(10))   ' Print farenheit
    str(13,9,$0A,$00,string("F"))
PRI updateBarom
    decxy(23, 9, $0B, $00,PSI)
    str(28,9,$0E,$00,string("2 decimals"))
PRI updateHDC  |  local_long
    local_long := HDC << 1 | 1
    I2C.command(HDC,$00)       'start a temp, hum measurement
    waitcnt(clkfreq/10+cnt)
    I2C.arbitrary(@local_long,1,@local_long,4)
    temp_C := local_long.byte[0] << 8 | local_long.byte[1]
    temp_C := temp_C * 165 / 65536 - 40
    Far := temp_C * 9/5+32
    decxy(10,11,$0A,$00,Far)  'this is outside temp
    str(13,11,$0A,$00,string("F"))
    RH := local_long.byte[2] << 8 | local_long.byte[3]
    RH := RH * 100 / 65536
    str(10,14,$0F,$00,string("RH"))
    decxy(13,14,$0A,$00,RH)
    str(15,14,$0A,$00,string("%"))
    DP := Far - ((100-RH)/5)
    str(17,14,$0F,$00,string("DP"))
    decxy(20,14,$0A,$00,DP)
    str(23,14,$0A,$00,string("F"))
PRI updateDir
    binxy(8, 16, $0E, $00, Winput, 8)              ' Print binary Winput               cyan on black
    case Winput
        %0000_0110:                 '128
            updateNeedle(@wind_N)
            str(12, 7, $0D, $00,string("N   "))
        %0000_0100:                 '129
            updateNeedle(@wind_NNE)
            str(12, 7, $0D, $00,string( "N NE"))
        %0000_1100:                 '1
            updateNeedle(@wind_NE)
            str(12, 7, $0D, $00,string("NE  "))
PRI updateNeedle(ptr) | x, y
    repeat y from 19 to 25
        repeat x from 2 to 8
            printxy(x, y, $0D, $00, byte[ptr++])            ' Print Needle             white on black
PRI init | i, j, k, p1, offs
''* Start  VGA Cog's, Clear Screen and  *
''* set Cursor's                                 *
    I2C.start(scl,sda,bitrate)
    offs := 62                                              ' 62 Bytes BMP-Header not used, 128x128 2 Color Bitmap
    repeat i from 15 to 0
        repeat j from 7 to 0
            p1 := (i * 16) + (j * 256)
            repeat k from 0 to 15
                fontbuff[p1+k] := reverse(font[offs++])
    wordfill(@vgabuff, $0F20, 1200)                         ' Clear Screen with $20 (Space) FG-Color $F (white), BG-Color $0 (black)
    vga.start(video, @vgabuff, @fontbuff, @cursor, @sync)   ' Start Video Driver
    waitcnt(clkfreq * 1 + cnt)                              ' wait 1 second for cogs to start
    I2C.writeWordB(HDC,Config_reg,Config_params)            'configure HDC
    str(0, 16, $0F, $00, @strWinput)          ' Print "Winput"                            white on black
PRI reverse(val) : new | i
''* Reverse a Byte                               *
''* eg. %01000000 = $40 to %00000010 = $02       *
    i := 1
    val <<= 32 - 8
    repeat 8
        if ((val <-= 1) & 1) == 1
            new += i
        i *= 2
PRI getPos(x, y)
    return (x + y * 40) * 2
PRI print(fgc, bgc, char)
''* Print Character char at current pos          *
''* with Foreground-Color fgc and                *
''*      Background-Color bgc                    *
    vgabuff[pos++] := char
    vgabuff[pos++] := bgc * 16 + fgc
PRI printxy(x, y, fgc, bgc, char)
    pos := getPos(x, y)
PRI str(x, y, fgc, bgc, string_ptr)
''* Print String at x, y                         *
    pos := (x + y * 40) * 2
    repeat strsize(string_ptr)
        print(fgc, bgc, byte[string_ptr++])
PRI drawBox(x, y, w, h, fgc, bgc) | t1, m, b, i
''* Draw Box at x, y with w = width, h = height  *
''* Foreground.Color fgc                         *
    t1 := (y * 40 + x) * 2
    m := t1 + 80
    b := m + ((h-2) * 80)
    pos := t1
    print(fgc, bgc, $80)
    fill(fgc, bgc, $81, w-2)
    print(fgc, bgc, $82)
    repeat i from 0 to h-3
        pos := m + i * 80
        print(fgc, bgc, $86)
        fill(fgc, bgc, $20, w-2)
    pos := b
    print(fgc, bgc, $83)
    print(fgc, bgc, $84)
PRI fill(fgc, bgc, char, len) | x
''* Fill len of Char's with char                 *
''* at current pos                               *
    if len <> 0
        repeat x from 1 to len
PRI decxy(x, y, fg, bg, val)
    pos := getPos(x, y)
    prn(fg, bg, val)
    print(fg, bg, $20)
PRI prn(fg, bg, val) | dig
    dig := 48 + (val // 10)
    val := val/10
    if val > 0
        prn(fg, bg, val)
    print(fg, bg, dig)
PRI binxy(x, y, fgc, bgc, value, digits)
''* Print binary value at x, y                   *
    value <<= 32 - digits
    repeat digits
        print(fgc, bgc, (value <-= 1) & 1 + "0")
PUB convert_measurements | X1, X2, X3, B3, B4, B5, B6, B7, oss
        ' converts uncalibrated UT and UP into calibrated temperature T and pressure P
    X1 := ((UT - AC6) * AC5) ~> 15           ' X1 := (UT - AC6) * AC5 / 2^15
    X2 := ~~MC << 11 / (X1 + ~~MD)           ' X2 := MC * 2^11 / (X1 + MD)
    B5 := X1 + X2                            ' B5 := X1 + X2
    T := (B5 + 8) ~> 4                      ' T  := (B5 + 8) / 2^4
    oss := 0
    B6 := B5 - 4000                          ' B6 := B5 - 4000
    X1 := (B2 * ((B6 * B6) ~> 12)) ~> 11   ' X1 := (B2 * (B6 * B6 / 2^12)) / 2^11
    X2 := (~~AC2 * B6) ~> 11               ' X2 := AC2 * B6 / 2^11
    X3 := X1 + X2                          ' X3 := X1 + X2
    B3 := (AC1 * 4 + X3) ~> 2            '* ' B3 := ((AC1 * 4 + X3) << oss + 2) / 4
    X1 := (~~AC3 * B6) ~> 13                    ' X1 := AC3 * B6 / 2^13
    X2 := (B1 * ((B6 * B6) ~> 12)) ~> 16        ' X2 := (B1 * (B6 * B6 / 2^12)) / 2^16
    X3 := ((X1 + X2) + 2) ~> 2                  ' X3 := ((X1 + X2) + 2) / 2^2
    B4 := (AC4 * (X3 + 32768)) ~> 15            ' B4 := AC4 * {(unsigned long)}(X3 + 32768) / 2^15
    B7 := (UP - B3) * (50000 >> oss)     '*     ' B7 := {((unsigned long))}(UP - B3) * (50000 >> oss)
    if (B7 < $8000_0000)                        ' if (B7 < $8000_0000)
      P := (B7 << 1) / B4                       '    p := (B7 * 2) / B4
    else                                        ' else
      P := (B7 / B4) << 1                       '    p := (B7 / B4) * 2
    X1 := (P ~> 8) * (P ~> 8)                   ' X1 := (p / 2^8) * (p/2^8)
    X1 := (X1 * 3038) ~> 16                     ' X1 := (X1 * 3038) / 2^16
    X2 := (-7357 * P) / 65536                   ' X2 := (-7357 * p) / 2^16
    P := P + (X1 + X2 + 3791) ~> 4              ' p := p + (X1 + X2 + 3791) / 2^4
PUB WindSpeed | PlsCnt'cog
         'Set up the counters
  ctra := %01110 << 26 + pin1     'counter A in NEG edge detect mode
  frqa  := 1               'increment 1 per pulse
       'pulse count loop
  repeat
    phsa := 0                         'reset count registers
    waitcnt(clkfreq *2 + cnt)  'wait gate time of 2 second
    PlsCnt := phsa                     'read the puls counts
             'convert pulse count to RPM and display
    speed := PlsCnt    'pulse average divided by 2 segments times 60 seconds
PUB hex(value, digits)
'' Returns pointer to a digits-wide hexadecimal string
  clrstr(@nstr, MAX_LEN)
  return hexstr(value, digits)
PRI clrstr(strAddr, size)
' Clears string at strAddr
' -- also resets global character pointer (idx)
  bytefill(strAddr, 0, size)                            ' clear string to zeros
  idx~                                                  ' reset index
PRI hexstr(value, digits)
' Converts value to digits-wide hexadecimal string equivalent
' -- characters written to current position of idx
' -- returns pointer to nstr
  digits := 1 #> digits <# 8                            ' qualify digits
  value <<= (8 - digits) << 2                           ' prep most significant digit
  repeat digits
    nstr[idx++] := lookupz((value <-= 4) & $F : "0".."9", "A".."F")
  return @nstr
PUB  RTCcog
   repeat
     I2C.readbytes(RTC,0,@timbuf,7)
     waitcnt(clkfreq /2 + cnt)
  • I forgot to include the screen shot
    3072 x 2304 - 861K
  • Tracy AllenTracy Allen Posts: 6,301
    edited 2018-05-31 - 01:19:28
    One possible cause of weirdness is i2c methods running async in two cogs. The RTCcog is hitting the i2c port every 1/2 second, and sooner or later it will clash with the i2c methods that are called in your main cog. This is a danger unless the i2c is protected with locks. In your program, it may be easier just to roll the call to the RTC back into the main loop in one cog.
  • I put the RTC in the main program (eliminated the RTC cog) but still after a while get some weird characters in various places.
    I've attached a screenshot with some garbage in the wind direction box.
    Could it have anything to do with initing the screen (writing the text words) at the beginning of the program and never refreshing it?
    As I write this, there has now appeared some garbage just after the wind direction data.
    Aaron
    3072 x 2304 - 2M
  • I just tried reiniting the screen every 2 minutes and so far so good
  • It looks like maybe the stack is inside the video buffer.
  • Hello,
    @AGCB
    you use my "VGACOLOR_320x240_CURSOR.spin" - Driver.
    Can you post the whole Code?
    Maybe i can help you.
    Greetings from Nuremberg, Germany
    Werner
  • Werner
    13,489 characters too long to post. Is there a way around this?
    Aaron
  • AGCB wrote: »
    Werner
    Aaron
    Zip it up in the Propeller tool, and attach the zip.
    Infernal Machine
  • I don't see hoe to 'zip it up'
  • I'll be away from computer till Monday AM so will not be able to reply to new posts.
    Thanks Aaron
  • @AGCB - sounds like others are helping solve your problem. Just wanted to say that this is a cool project. Best of luck.
    Whit+
  • Hello Aaron,
    i think i found the Error:
    The "decxy" Method in the Mainloop and the "decxy" in the "Windspeed"-Cog
    fight against each other. :lol:
    Make this Changes:
    DAT
    ' Add the new "pos2" var, add "print2", "decxy2" and "prn2"
    ' Change in "WindSpeed" "decxy" to "decxy2"
    ' Hope this will help...
    VAR
        long pos2                          ' Global Screen-Pointer #2
    PRI print2(fgc, bgc, char)
    ''* Print Character char at current pos2         *
        vgabuff[pos2++] := char
        vgabuff[pos2++] := bgc * 16 + fgc
    PRI decxy2(x, y, fg, bg, val)
        pos2 := getPos(x, y)
        prn2(fg, bg, val)
        print2(fg, bg, $20)
    PRI prn2(fg, bg, val) | dig
        val := val/10
        if val > 0
            prn2(fg, bg, val)
        print2(fg, bg, dig)
           'pulse count loop
      repeat
    '    decxy(11, 3, $08, $00, speed)
        decxy2(11, 3, $08, $00, speed)                      ' use it's own "decxy" Method
    Werner
  • That was the problem? Thanks. Even overnight, no garbage.
    Werner, how do I get a 'degree symbol' to print in VGA? When I put one in from the Propeller font is just gives a squiggly line.
    Aaron
  • Werner
    Would you please give me some basic info on how to use that Cp437_8_new.bmp font. I've tried to figure it out on my own but haven't.
    Aaron
  • Hello Aaron,
    the "CP437_8_NEW.BMP" (256 Colors) is the Template for the "CP437_8.BMP" (2 Colors).
    In the "CP437_8_NEW.BMP" (256 Colors) i see the unused Characters. (green/darkgreen)
    The "CP437_8.BMP" must have only 2 Colors.
    The 'degree symbol' is always available in the "CP437_8.BMP" File, as Char $BF,
    The green Char:
        str(13, 9, $0A, $00, @strF)                      ' Print "°F"
    DAT
    strF              byte $BF, "F", 0
    I hope all is clear...
    Werner
  • Thanks Werner! I think I got it.
    Aaron
  • It's been working great for months! I still get a few spurious characters in or around the needle graphic but not so as to be much of a bother.
    However, I'd like to do a few changes in the program code but can't seem to get in. When I try it says "can't find file CP437_8.bmp in work folder or library". I tried to add it to library but it won't allow. It is already in the same folder as the main code.(I think)
    I've tried multiple things to correct this to no avail. I remember having the same problem when I was 1st working on this but somehow got it to work.
    I wanted to see if there were any cogs left to put in a 'onewire' temperature display and also wanted to add a automatic daylight savings time correction.
    Please advise me.
    Aaron
  • Is there a way to tell easily how many COGs a program is using?
