And just to check... you've found the API document ?
All the serial commands are detailed there.
From memory, you might want to set either DO or DI low for a few milliseconds, to toggle the ESP module between serial command mode and transparent mode. The API describes that too.
For example, this snippet joins a network:
https://www.parallax.com/downloads/parallax-wx-wi-fi-module-firmware-guide
I've heard that there is a new way to add Wi-Fi connectivity, is this true?
Is it listed in this guide?
Could you share a link and/or explain "what you've heard" ?
