Eddie Rev B USB Connector — Parallax Forums
Hi all,
I was just able to purchase an Eddie robot in pretty rough shape with the Rev B controller. One wheel shaft was bent and the Kinect riser and Kinect are missing.
Worse, I found the USB connector has been ripped from the board an would like to replace it. Does anyone know the manufacturer and model number of the connector?
Thanks in advance.
Will
  • Hi Willpoll,
    I've found the internal part number but not the manufacturer reference. If you can wait ~24 hours, I'll ask someone in stores to check the details for you. Will update here soon!
  • Thanks!!
    That would be awesome.
    -Will
  • @willpoll
    The original part is now obsolete (1-440247-1).
    I found you a direct replacement, which is currently in stock:
    Digi-Key Part Number          A111050-ND
    Manufacturer Part Number      1734035-1
    Description	              CONN MINI B USB R/A SMD
  • Nice sleuthing there!
  • Thanks so much, you're a life saver!
    -Will
