how do I loop for x seconds?
hey guys,
how do I loop a function for a certain number of seconds?
Thanks!
  • Tracy AllenTracy Allen Posts: 6,310
    edited 2018-02-12 - 17:50:41
    We probably need more information in order to answer that. One common way to do that refers to the system clock register.
    ticks := clkfreq * Nseconds + cnt  ' the system clock at N seconds in the future
        ' provided the cnt <2^32,  ~(53/2) seconds at clkfreq=80MHz
    repeat
      ' do whatever
      if cnt - ticks > 0   ' wait that number of seconds with uncertainty for the whatever code
        quit
  • 1. Put a waitcnt in the function to force it to take a known amount of time.
    2. repeat the loop 1_000 or 1_000_000 divided by the know loop time.
    Re-inventing the wheel is not a waste of time if, when you are done, you understand why it is round.
  • In Spin,
    If x < 27, use this:
    t0 := cnt
    repeat until (cnt - t0 => x * clkfreq)
      'Do stuff for x seconds
    Otherwise, this:
    t0 := cnt
    repeat x
      repeat until (cnt - t0 => clkfreq)
      t0 += clkfreq
    In both cases, it's assumed that "do stuff" doesn't take very long to perform.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • What about in C?
  • Someone proficient in C will have to answer. I'm not.
  • mikeologistmikeologist Posts: 337
    edited 2018-02-11 - 02:09:08
    Any com port in a storm.
    Floating point numbers will be our downfall; count on it.
    Imagine a world without hypothetical situations.
  • mikeologist,
    Um, if ints are signed, that won't work. Also, even if ints are unsigned, that code is only good for times less than 54 seconds.
    edited 2018-02-11 - 02:08:51
  • It's an easy translation from Phils Spin code to C:
    The first one with x < 27 seconds:
    int t0 = CNT;
    while (CNT - t0 < x * CLKFREQ)
      //Do stuff for x seconds
  • This function if available on Arduino as micros and millis.
    I needed to keep track of the time and then do something and I needed multiple timers to do it so I wrote a library function for it.
    int micros(unsigned long *D)
      long t;
      t = CNT + 280 - *D;
      *D = CNT;
      if (t < 0)
        t = UINT32_MAX + t;
      *D = *D - t % us;
      t = t/us;
      return t;
    int millis(unsigned long *D)
      long t;
      t = CNT + 280 - *D;
      *D = CNT;
      if (t < 0)
        t = UINT32_MAX + t;
      *D = *D - t % ms;
      t = t/ms;
      return t;
    Buy passing in a long variable you can keep track of multiple time instances.
    unsigned long PCNT;
    unsigned long P2CNT;
    int main()
      int sec, sec2;
      int d1, d2;
      micros(&PCNT);
      millis(&P2CNT);
      sec = 0;
      sec2 = 0;
      d1 = 0;
      d2 = 0;
      while(1)
        d1 += micros(&PCNT);
        d2 += millis(&P2CNT);
        if (d1 > 1000000)  // wait a second
          d1 = d1 - 1000000;
          print("Timer: %d, %d\n", d1, sec++);
        if (d2 > 1000) // wait a second
          d2 = d2 - 1000;
          print("Timer2: %d, %d\n", d2, sec2++);
    You can also use the mstimer.h library that starts a cog with the time in it.
