Programing Lee Hart's ELF - A Propeller/Tachyon Application
nglordinglordi Posts: 114
edited 2018-02-10 - 19:11:36 in Customer Projects
Lee Hart's ELF Membership Card is an 8 bit retro computer based on the RCA 1802 (COSMAC) chip. It can be programed using a bank of 8 switches or through a parallel port. A propeller running TACHYON has been programed to control the ELF. The attached figure shows the hardware setup.
The ELF has a DB25 parallel port which is connected to a propeller FLIP. A small PCB was designed to make this connection. The white cable connects to the 1802 output port and the black cable connects to the 1802 input port. A 4 bit multicolored cable connects to the control port. A SD card was added for program storage. A 5 volt Li-ion rechargeable battery provides power to the ELF and FLIP. The USB port on the FLIP enables communication with a terminal emulation on a PC or other device.
The png attachment is a chart which summarizes the flow of information in the tachyon program. The basic components of the software are two 512 byte blocks: SDBUF, which is the path to the SD card, and CODE, which holds user defined programs. If an existing program file is opened on the SD, the program can be downloaded to SDBUF and then written to the 1802 memory for execution. A new program is loaded in the CODE block where it can be edited, written to the 1802 for testing, and transferred to SDBUF for loading in a new SD file.
The TXT attachment lists the actual tachyon software with comments. This software includes an optional module which adds the 1802 assembly language to the program, giving the user an option to write programs in the code block using assembly instructions. I have an example of the approach I use to write new code in this environment. There is also a list of tachyon words that are needed to effectively use the program and references to Lee Hart's ELF.
1244 x 1182 - 437K
444 x 534 - 14K
  • Very cool retro project. I had to look up what the RCA 1802 or the ELF was used for, but i dig on retro tech. Do you have any videos of it in action?
    Joshua Donelson
    http://jdpresents.com/
  • The COSMAC ELF was my first computer. And, yes, I just ordered one of those ELF Membership Card kits.
    Jon McPhalen
    Hollywood, CA
    It's Jon or JonnyMac -- please do not call me Jonny.
