Is it possible to single-step a prop1? — Parallax Forums
Hi Prop-fiends! long time no see :-)
Question regarding stepping:
We have the internal clock.
We can attack an external crystal.
Using a 555 timer, or signal generator, or some other mechanism... is it possible to get a propeller to slow down to a few hertz... or even stop / resume?
Red
  • jmgjmg Posts: 15,145
    edited 2018-01-07 01:02
    __red__ wrote: »
    ..... is it possible to get a propeller to slow down to a few hertz... or even stop / resume?
    The Prop is Static CMOS, so yes, you can clock from an external clock, of any speed slower than Max. Right down to DC.
    If you look at Propeller™ P8X32A Datasheet 8.0 CURRENT CONSUMPTION CHARACTERISTICS, you can see values graphed down to 100Hz, & below 1kHz there is little reduction in current.
    That is at 3.3V, but if you are clocking very slowly, you can drop Vcc down.
    Some more Vcc/Icc figures in this thread...
    http://forums.parallax.com/discussion/129731/prop-limbo-how-low-power-voltage-can-it-go/p1
    I wrote a debugger (LMM_debugger) that is capable of tracing/single-stepping a PASM or SPIN Cog. IIRC it's in the OBEX.
