rc transmitter for ardupilot
hello,
i will build my first multicopter and plan to use arducopter.
can you advise a simple and reasonably priced rc transmitter that would be compatible? i will just build something very simple just to build something this is all. i need nothing fancy
  • 4 Comments sorted by Date Added Votes
  • What model of flight controller are going to use. There are several models.
    Any receiver that outputs SBus is a good choice.
    You can also use either of the radios sold by Parallax such as this one: https://www.parallax.com/product/80208
    Hobby king also has an inexpensive radio for about $60. https://hobbyking.com/en_us/turnigy-evolution-fpv-radio-mode-2-white.html
    This unit has limited range of about 500 meters and there is no channel mapping to change the switch functions and will make changing flight modes a little difficult but usable.
  • You can get a Flysky 6 channel for just over $40 if you need to go inexpensive. I think Turnigy is about the same level. I'm looking at something programmable with Open TX firmware for the long run myself, http://www.open-tx.org/radios , but that might be a little much for the project you describe. Frsky, Futaba, Hi-tec and of course Spektrum all make good models if you can get a deal on any if them.
    Definitely go with 2.8GHz if buying new, but the older Futaba 6+ CH FM (72MHz) are actually nice rigs to fly with if you happen to walk into a used complete set for next to nothing.
    If you're going with RX4 stuff instead of the Parallax Elev-8 flight controller, I would take a hard look at a Pixhawk or Pixhawk mini for the latest firmware capabilities. Arguably the most robust flight controller on the market. I might build one up to test against the Elev-8 V3 at some point.
  • I use a Turnigy 9XR Pro with X8R receiver and XJT transmitter with my PixRacer and PixHawk Ardupilots.
    Works great.
  • I recommend against using any transmitter where you install AA style batteries. That's really sketchy for something somewhat safety critical.
    Using that as my criteria, I found the best price for a basic transmitter system at Tower Hobbies.
    I am the Master, and technology my slave.
