Designing Circuit Boards
ajward
Hey Everyone...
Does anyone have a link to a SIMPLE tutorial for using Eagle to design circuit boards? I've tried using the program to create a simple board using a 78XX regulator to get a circuit board for various power supplies.
I've laid out the components in a as they might be drawn on paper, but when I try to create a circuit board, the traces criss cross the window like a child's scribbling!
Heck... if someone has such boards, I'd be happy to buy a few!
Any assistance would be greatly appreciated!
Amanda
Amanda
There are much better regulators out there than the 78xx.
What current output are you expecting because you may need to heat sink the regulator and use thick traces?
Check and check and check again that your footprints match your physical parts!
I found these 2 Tutorials
https://learn.sparkfun.com/tutorials/using-eagle-board-layout
http://www.instructables.com/id/PCB-Creation-with-Eagle-for-Beginners/
And of course, here
http://eagle.autodesk.com/eagle/documentation
The more direct and straight connections that you can make pins, the easier it will be to route everything else so move parts around and remember that you can also ROTATE parts.
Which version of Eagle are you using?
Oh, by the way, that jumble of wires is what is called a "rat's nest".
Also, before you start routing are you sure that your schematic is correct and have you built and tested this circuit to be sure it works?
Nothing is worse than wasting time on a mistake.
1.) Are ground loops a big concern and how would one layout a "Star" point (a common point that all grounds branch off from)?
2.) How close/far should the large electrolytic filter capacitors be from the regulators to be cool yet still function?
Oh, and Amanda you should consider using polarized or idiot-proof connectors instead of just wires or headers. This is known as Poke Yoke which is Japanese for mistake proofing.
I think, just by what you are describing, you may just be seeing the un-routed "rats nest"/"air wires". YouTube has several really good videos by searching "eagle board layout tutorial"'s. What I think you are seeing is where the connections come and go to according to your schematic, aka "rats nest"/"air wires" which is what is will be called in documentation you are reading or may have read.
Picture a pack rat's collection of string, yarn, etc. all balled up in a pile.
Thanks for all the great answers!
I'll check out the links this weekend. Not looking for an industrial class PS, just something simple to charge a small handheld, dual-band (2m/70cm) radio from the 12v outlet in my car. Nothing elaborate, possibly just the 7810 and a couple of caps.
Yeah, I know I could just buy one but where's the fun in that?
Lastly (although there wasn't a firstly :->) I want to say how much I appreciate the vast amount of knowledge available on the forums!! I often have questions that stray from Parallax products but someone always seems to have a great answer. What an awesome resource!
Amanda Ward
These days switching regulators are almost universally used and if it is simply for charging then you might not have to worry about low car battery volts. Maybe the 7810 will work fine, but it may get quite hot. BTW, don't copy circuits from the web that have big electrolytics on the output of the regulator as they may have uses on the input, but the reason for the regulator is that it ... well....regulates. Besides electrolytics have very poor response at regulation "frequencies" which is why most circuits will show a very small ceramic cap on the output and maybe a small tantalum that are effective.
