Iteratively assigning cog variables from Main RAM — Parallax Forums
How's it going everyone?
I've finished my VGA driver which is able to output a 640x480 VGA signal @ 60 Hz, compatible with both 8x8 and 16x16 tiles. In order to support this flexibility (as well as the ability to define custom screen tile dimensions and memory tile map dimensions) I calculate a fair number of attributes in the hub which are then passed to the VGA driver cog. Right now, I'm setting these internal registers in the following way (the full code can be viewed here):
' Initialize frame attributes
        mov             csl,    #0              ' Initialize upscale tracking register
        mov             attptr, par             ' Set attribute pointer
        add             attptr, #4              ' Iterate through attributes and set external to internal equivalents
        rdlong          vTilesH,attptr
        mov             numTL,  vTilesH
        add             attptr, #4
        rdlong          vTilesV,attptr
        mov             numTF,  vTilesV
        add             attptr, #4
        rdlong          tSizeH,attptr
        add             attptr, #4
        rdlong          tSizeV,attptr
        add             attptr, #4
        rdlong          tMapSizeH,attptr
        add             attptr, #4
        rdlong          tMapSizeV,attptr
        add             attptr, #4
        rdlong          tMemSizeH,attptr
        add             attptr, #4
        rdlong          tSize,attptr
        add             attptr, #4
        rdlong          tOffset,attptr
        add             attptr, #4
        rdlong          vLineSize,attptr
        add             attptr, #4
        rdlong          tMapLineSize,attptr
        add             attptr, #4
        rdlong          tlslRatio,attptr
        mov             slr,    tlslRatio
        sub             slr,    #1
        add             attptr, #4
        rdlong          lPerTile,attptr
        mov             numLT,  lPerTile
        add             attptr, #4
        rdlong          cPerFrame,attptr
        add             attptr, #4
        rdlong          cPerPixel,attptr
        add             attptr, #4
        rdlong          vSclVal,attptr
As you can see, this is hideous and it seems to me that it MUST be excessively explicit.
Is there a way to iteratively (i.e. using a loop) set internal cog registers? Thank you!
  • JonnyMacJonnyMac Posts: 8,924
    edited 2017-11-06 02:54
    Yes.
    In my rgbw pixel driver I have six variables than need to be passed to the PASM driver. The address of connection is passed in par.
      long  connection                                              ' compressed connection details
      long  resetticks                                              ' ticks in reset period
      long  rgfix                                                   ' swap r&g? + bit count for pixels
      long  t0h                                                     ' bit0 high time (ticks)
      long  t1h                                                     ' bit1 high time (ticks)
      long  cycleticks                                              ' ticks in 1.25us
    And here's the top of my PASM code that copies moves these six values into the cog.
    pixdriver               mov     t1, par                         ' hub address of parameters -> t1
                            movd    :read, #connect                 ' location of cog parameters -> :read(dest)
                            mov     t2, #6                          ' get 6 parameters
    :read                   rdlong  0-0, t1                         ' copy parameter from hub to cog
                            add     t1, #4                          ' next hub element
                            add     :read, INC_DEST                 ' next cog element
                            djnz    t2, #:read                      ' done?
    I didn't create this strategy (Chip probably did) -- though I do take advantage of it.
    In your case, you might do something else. The loop moves the values from hub to cog, the next section takes care of the extra mov instructions. It's probably obvious, but your hub and cog variables must be laid out in the same order.
                            mov     t1, par
                            add     t1, #4
                            movd    :read, #vTilesH
                            mov     t2, #16
                            add     t1, #4
                            add     :read, INC_DEST
                            djnz    t2, #:read
                            mov     numTL, vTilesH
                            mov     numTF, vTilesV
                            mov     slr, tlslRatio
                            sub     slr, #1
                            mov     numLT, lPerTile
  • Have a look at vga.spin, it updates its cog registers from hub.
    ' Tasks - performed in sections during invisible back porch lines
    tasks                   mov     t1,par                  'load parameters
                            movd    :par,#_enable           '(skip _status)
                            mov     t2,#paramcount - 1
    :load                   add     t1,#4
    :par                    rdlong  0,t1
                            add     :par,d0
                            djnz    t2,#:load               '+164
  • One thing if you are running out of cog room: Since that code only gets executed once in its life, you can reuse the locations:
    attptr  mov             csl,    #0              ' Initialize upscale tracking register
    vTilesH mov             attptr, par             ' Set attribute pointer
    numTL   add             attptr, #4              ' Iterate through attributes and set external to internal equivalents
    vTilesV rdlong          vTilesH,attptr
    numTF   mov             numTL,  vTilesH
    tSizeH  add             attptr, #4
    tSizeV  rdlong          vTilesV,attptr
    tMapSizeH mov             numTF,  vTilesV
    tMapSizeV add             attptr, #4
    etc    rdlong          tSizeH,attptr
            add             attptr, #4
            add             attptr, #4
            add             attptr, #4
    Especially hideous and obfuscating
  • roglohrogloh Posts: 5,158
    edited 2017-11-06 23:53
    Yeah although it's a particularly handy way to maximize the resources available in the COG.
    Actually I find that form of instruction space reuse after initialization not so bad. It gets a lot trickier when you have code being dynamically modified during its execution and registers being reused in different parts of the code for different purposes when they can be. Then deciphering the code and tracking problems down can become rather difficult, you need a lot of coffee for that. I've resorted to basically using all of those techniques in tight spots where you have to fit everything in the COG and get it to run in realtime - it's saved me quite a few times when writing video drivers etc where you also have to store a fair bit of data in the COG as well.
    I remember way back in undergrad Computer Science classes they would teach you that space can be traded for time in software. Once you try to wring everything out of a propeller chip in PASM that connection is clearly demonstrated.
  • Thanks for the outstanding help guys. The idea of overwriting instructions w/ memory is absolutely bizarre but awesome.
  • escherescher Posts: 138
    edited 2017-11-07 03:25
    JonnyMac wrote: »
    Yes.
                            mov     t1, par
                            add     t1, #4
                            mov     t2, #16
                            add     t1, #4
                            add     :read, INC_DEST
                            djnz    t2, #:read
                            mov     numTL, vTilesH
                            mov     numTF, vTilesV
                            mov     slr, tlslRatio
                            sub     slr, #1
                            mov     numLT, lPerTile
    @JonnyMac you didn't mention you had a full walkthrough of this strategy: http://radio-hobby.org/uploads/journal/NV/2013/NV_09_2013.pdf
    That article is outstanding, and your code worked perfectly in my application.
    edited 2017-11-07 17:46
    Again, I simply followed the road paved by other programmers relative to transferring data from the hub to a cog.
    FWIW... I have made a lot of changes/improvements over the years to my pixel driver. The latest is in ObEx.
