P1v on a Prop123-A9?
Has anyone used the Prop123-A9 board for playing with P1v?
  • Yep
    A while back I made a P123-A9 test image based on P1V
    See here
    The P123-A9 board is a great board for P1V with tons of IO and the big FPGA gives you 1MB hub.
    Melbourne, Australia
  • See here: http://forums.parallax.com/discussion/comment/1421880/#Comment_1421880
    Where you originally posted the question.
  • ozpropdev, can you post the source code to your project, or at least your .qsf and top-level Verilog file? I would like to add it to my P1V repo.
    If your source code is in Github or in a Git repository that I can reach from the internet, that would be even better.
    ===Jac
    Rancho Cucamonga, CA
  • Heater. wrote: »
    Oops, sorry. I realized after I posted that that it was hijacking an unrelated thread so I created a new one. Thanks for the pointer!
  • jac_goudsmitjac_goudsmit Posts: 415
    edited 2017-10-29 - 08:01:16
    Sorry to revive an old thread but I'd like to report that earlier today I created an fpga-123 A9 target in my P1V repo at https://github.com/JacGoudsmit/P1V. I don't have an FPGA-123 (unfortunately) so I can't test it any further than building it, so let me know if it works.
    I also did a lot of other maintenance lately so all the targets are now based on this hierarchy:
    Top level module (different for each target)
    Reset module
    Clock module (different between Altera, Xilinx and future platforms
    "Dig" module by Chip
    "Hub" Hub logic
    "Hub_mem" Hub ROM/RAM
    "Cog" instantiated 8 times by default)
    "Cog_alu" Arithmetic/logic unit
    "Cog_ram" RAM
    "Cog_ctr" counters, instantiated twice
    "Cog_vid" video
    The documentation has also been reorganized a little, and I have some more reorganization in mind. For example I want to "break out" the hub memory to the top module because that's where most of the interesting customizations have happened and will happen. I'm thinking of things like:
    • Different hub RAM size
    • Using SRAM or DDR RAM chips as hub RAM
    • Scrambled vs. unscrambled ROMs
    • Removal of ROM areas (e.g. font ROM in the DE0-Nano)
    • Alternate boot loaders etc.
    Meanwhile, Andy Silverman has been doing a lot of work on adding some cool features to the Digilent Nexys4 target, and I'll be adding the DE2 (Cyclone 2) target "real soon now".
    ===Jac
