Dry Erase Markers for Scribbler, S2, and S3
WhitWhit Posts: 4,057
edited 2017-09-24 - 04:14:17 in Robotics
Found these at Wal-mart yesterday. Same barrel size as a Sharpie and work great with any Scribbler!
U Brands Low Odor Dry Erase Markers With Erasers, Medium Point, Assorted Colors, 10-Count
Whit+
  • That's neat Whit. So fit them backward and you got a robotic eraser. A self tidying helper if you will; such a rare treat!
  • @VonSzarvas - I was thinking the same thing! Will check it out...
    Whit+
  • Keep us up to date with this. I've been wanting to build a dry erase table if I ever found a good size dry erase marker.
    Is this getting the wheels crummy?
    Is the line follower working with drawn lines?
    Founder of Kinvert
    https://www.kinvert.com/
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 22,331
    edited 2017-09-24 - 21:27:05
    I've used the smaller dry-erase markers, and they work just fine. Just wrap them with enough masking tape to slide in the hole without wobbling. I've found that it also helps to wrap the top of the marker with solder, taped down, to add a little extra heft and pen pressure.
    I've seen no evidence to suggest that the tires get crudded up by dry-erase residue.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • ercoerco Posts: 19,454
    Out of stock! Woe is me!
    "When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
    - Pablo Picasso
