Forum Update - Announcement about May 10th, 2018 update and your password.
Block move SETQ/Cordic related issue
Hi Chip
I've found an issue with the Cordic giving incorrect results when preceeded by a block move instruction pair.
I have to insert a spacer instruction between to get correct results.
The spacer instution can be any instruction.
It almost like a SETQ value of $FFFFFFFF is being passed into the cordic.
I went back to V18 FPGA image and the issue was there too.
Here's some example code for the P123 board to demonstrate the issue.
dat		org
		loc	pa,#\parms
		loc	ptrb,#@mycode
		setq	pa
		coginit	#16,ptrb
		cogstop	#0
dat		orgh	$400
parms		long	60_000_000	'parameter block
		long	115200
		long	63
		long	62
		org
mycode		bmask	dirb,#15	'enable leds
		setq	#3
		rdlong	parm1,ptra	'block move 4 longs
		nop	'???? Needed for correct Cordic result ????
		qdiv	parm1,parm2
		getqx	outb		'show result on leds
		jmp	#$
parm1		long	0
parm2		long	0
parm3		long	0
parm4		long	0
Melbourne, Australia
