How versatile is my stepper motor driver software?
DavidZemonDavidZemon Posts: 2,389
I wrote some code for a stepper motor and I'm now working on the docs. I want to ensure the docs reflect exactly what it can and can not do.
I have a bipolar and 5-wire unipolar stepper to test with, so I know it works great for those two types. And if I understand it right, those are the only two that can share software, right? The 6- and 8-wire unipolars require different code? I know you can tie certain wires together to create either a bipolar or 5-wire unipolar from 6- and 8-wire unipolars, but I'm not concerned about explaining that in my docs.
Here's the code I have (probably not necessary to answer my question, but just in case), and thank you in advance.
 * @brief   4-pin bipolar and 5-pin unipolar stepper motor driver
class Stepper {
    public:
         * @brief   Default delay in microseconds used between each step
        static const unsigned int DEFAULT_DELAY = 10000;
        enum class Step {
                HALF,
                ONE,
                ONE_AND_A_HALF,
                TWO,
                TWO_AND_A_HALF,
                THREE,
                THREE_AND_A_HALF,
                FOUR
    public:
         * @brief       Constructor
         * @param[in]   phase1Mask  Pin mask connected to phase 1
         * @param[in]   phase2Mask  Pin mask connected to phase 2
         * @param[in]   phase3Mask  Pin mask connected to phase 3
         * @param[in]   phase4Mask  Pin mask connected to phase 4
         * @param[in]   start       What step should the motor start with
        Stepper (const Pin::Mask phase1Mask, const Pin::Mask phase2Mask, const Pin::Mask phase3Mask,
                 const Pin::Mask phase4Mask, const Step start = Step::HALF)
            : m_currentStep(start),
              m_phase1(phase1Mask, Pin::Dir::OUT),
              m_phase2(phase2Mask, Pin::Dir::OUT),
              m_phase3(phase3Mask, Pin::Dir::OUT),
              m_phase4(phase4Mask, Pin::Dir::OUT) {
            this->set_step();
         * @brief           Move the motor directly to the specified step
         * @param step[in]  Step to move to
        void set_step (const Stepper::Step step) {
            this->m_currentStep = step;
            this->set_step();
         * @brief       Get the current step
         * @return      Current step where the motor is holding
        Step get_step () const {
            return this->m_currentStep;
         * @brief                   Step the motor to the nearest half-step to achieve a full-power hold
         * @param direction[in]     True for forward, false for backward
         * @param usDelay           Delay in microseconds after the step is taken (must be greater than 17 for lmm)
         * @return                  True if the motor requirement movement to achieve full-power hold, false if the
         *                          motor was already on a full-power hold
        bool full_power_hold (const bool direction, const unsigned int usDelay = DEFAULT_DELAY) {
            const bool movementNeeded = static_cast<bool>(static_cast<uint32_t>(this->m_currentStep) % 2);
            if (movementNeeded) {
                if (direction)
                    this->half_forward(1, usDelay);
                else
                    this->half_reverse(1, usDelay);
            return movementNeeded;
         * @brief                   Step the motor to the nearest full-step to achieve a half-power hold
         * @return                  True if the motor requirement movement to achieve half-power hold, false if the
         *                          motor was already on a half-power hold
        bool half_power_hold (const bool direction, const unsigned int usDelay = DEFAULT_DELAY) {
            const bool movementNeeded = !static_cast<bool>(static_cast<uint32_t>(this->m_currentStep) % 2);
                if (direction)
                else
         * @brief       Move the motor forward by a specified number of steps
         * @param[in]   steps       Number of steps to move forward
         * @param[in]   usDelay     Delay in microseconds between steps (must be greater than 17 for lmm)
        void step_forward (unsigned int steps, const unsigned int usDelay = DEFAULT_DELAY) {
            while (steps--) {
                const unsigned int stepNumber = static_cast<unsigned int>(this->m_currentStep) + 2;
                this->m_currentStep = static_cast<Step>(stepNumber % 8);
                this->set_step();
                waitcnt(usDelay * MICROSECOND + CNT);
         * @brief       Move the motor forward the a specified number of half-steps
         * @param[in]   halfSteps   Number of half-steps to move forward
         * @param[in]   usDelay     Delay in microseconds between half-steps (must be greater than 17 for lmm)
        void half_forward (unsigned int halfSteps, const unsigned int usDelay = DEFAULT_DELAY) {
            while (halfSteps--) {
                const unsigned int stepNumber = static_cast<unsigned int>(this->m_currentStep) + 1;
                this->set_step();
         * @brief       Move the motor backward by a specified number of steps
         * @param[in]   steps       Number of steps to move backward
        void step_reverse (unsigned int steps, const unsigned int usDelay = DEFAULT_DELAY) {
            while (steps--) {
                const unsigned int stepNumber = static_cast<unsigned int>(this->m_currentStep) + 6;
                this->set_step();
         * @brief       Move the motor backward by a specified number of half-steps
         * @param[in]   halfSteps   Number of half-steps to move backward
        void half_reverse (unsigned int halfSteps, const unsigned int usDelay = DEFAULT_DELAY) {
                const unsigned int stepNumber = static_cast<unsigned int>(this->m_currentStep) + 7;
                this->set_step();
    private:
         * @brief   Move the motor to the step specified
        void set_step () {
            switch (this->m_currentStep) {
                case Step::HALF:
                    this->m_phase1.set();
                    this->m_phase2.set();
                    this->m_phase3.clear();
                    this->m_phase4.clear();
                    break;
                case Step::ONE:
                    this->m_phase1.clear();
                    break;
                case Step::ONE_AND_A_HALF:
                    this->m_phase3.set();
                    break;
                case Step::TWO:
                    this->m_phase2.clear();
                    break;
                case Step::TWO_AND_A_HALF:
                    this->m_phase4.set();
                    break;
                case Step::THREE:
                    break;
                case Step::THREE_AND_A_HALF:
                    break;
                case Step::FOUR:
                    break;
    private:
        Step m_currentStep;
        Pin  m_phase1;
        Pin  m_phase2;
        Pin  m_phase3;
        Pin  m_phase4;
David
PropWare: C++ HAL (Hardware Abstraction Layer) for PropGCC; Robust build system using CMake; Integrated Simple Library, libpropeller, and libPropelleruino (Arduino port); Instructions for Eclipse and JetBrain's CLion; Example projects; Doxygen documentation
Tag me with "@DavidZemon" if you have a question for me. I will be checking these forums far less for the forseeable future.
