Who Needs 37 Sensors for $12?
ercoerco Posts: 18,731
edited June 2017 in Robotics Vote Up0Vote Down
Edit: I originally posted about this 16-sensor kit for $10, then DaveJenson out-ercoed me with his 37-sensor kit for $12. Even I couldn't resist. DOH!
Rule the world with this rogue's gallery of sensors... http://www.ebay.com/itm/Geekcreit-16-In-1-Sensor-Module-Kit-Laser-Ultrasonic-Obstacle-Avoidance-New-/222546682905
"When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
- Pablo Picasso
  • 16 Comments sorted by Date Added Votes
  • Well played, my young Padawan!
    - Pablo Picasso
  • ercoerco Posts: 18,731
    edited June 2017 Vote Up0Vote Down
    I ordered DaveJenson's kit. For $12, Mr. Roboto needs to check it out. Maybe there's a new contest in the offing to see who can use the most sensors on one project...
    Thanks Dave, you're keeping me on my toes!
    Edit: Changing the title.
    - Pablo Picasso
  • .. it includes a flame sensor module
  • Noted! :)
    - Pablo Picasso
  • I imagine this:
    1x Optical broken module
    is actually this
    Position sensors that activate when an object interrupts a light beam
    but I was amused.
    Re-inventing the wheel is not a waste of time if, when you are done, you understand why it is round.
    Cool, CA, USA 95614
  • Tor wrote: »
    That's what I typically use my fingers for. Reset time is a little long, though, usually on the order of 2-3 days.
  • Tor wrote: »
    Reminds me of the "Statue of Liberty" shots we used to do with Sambuca. Soak your fingers in the drink, then set 'em on fire & hold aloft until you take the shot. It doesn't pay to dally.
    - Pablo Picasso
  • So this could use a lot of the sensors: a mobile burglar deterrent system, following a line around the area on patrol. It warns the miscreant with flashing leds..and ultimately flames him...and then measures the crispiness of the result.
    San Mateo, CA
  • Love it! And I've always been a fan of "Crispy Critters".
    - Pablo Picasso
  • I think the question should be, "Who DOESN'T need 37 sensors for $12??"
    Let''s see somebody fess up to that!
    MOV OUTA, PEACE <div>Rick </div><div>"I've stopped using programming languages with Garbage Collection, they keep deleting my source code!!"</div>
  • Hey Hey Hey! Rick/mindrobots is IN THE HOUSE! Welcome back brother, you have been missed!!!
    - Pablo Picasso
  • Got my sensor kit today, having fun going through it sorting out my treasures. All 37 "sensors" (some are beepers or LEDs) present and accounted for. The sum of the parts is worth more than $12, if you can use them all...
    Found this site with more sensor info: https://tkkrlab.nl/wiki/Arduino_37_sensors
    Some interesting stuff. Most of them have pullup/pulldown resistors built in.
    But someone please tell me why this reed switch needs an
    lm393 comparator? https://tkkrlab.nl/wiki/Arduino_KY-025_Reed_module ?
    The touch sensor uses the base lead of a KSP13 darlington transistor as the touch point: https://www.alibaba.com/product-detail/AD-036-Metal-Touch-Interface-sensor_1890926598.html
    Optical pulse sensor: http://www.ebay.com/itm/Keyestudio-Heartbeat-Detect-Sensor-Finger-Pulse-Rate-Monitor-Module-FOR-Arduino-/311692638533
    Nice impact sensor, spring inside cylinder: https://tkkrlab.nl/wiki/Arduino_KY-002_Vibration_switch_module
    My list with a few notes attached.
    - Pablo Picasso
  • erco wrote: »
    Probably for debouncing. Reed switches are notoriously noisy.
  • Reed switches are notoriously noisy.
    So are my neighbors.
    I wonder if they would sit still long enough for me to solder them to a comparator. Or maybe just a big fat capacitor.
    Thanks for the suggestion!
    - Pablo Picasso
