Prop died at a site
T Chap
in Propeller 1
The Prop was fine for days. When I left they were welding steel with an electric system within 6' of the Prop enclosure. Since that day it has not been turned on, today the Prop is DOA. I never ever had a Prop die in my systems. Is it possible the welding killed it?
What's feeding it? May have been voltage spikes killed the on board regulators.
EDIT: I'm sure you already checked voltages.
As for the causes, don't go guessing too much just yet but the two generally tough ones to keep on your mind are:
1) Powerful RFI (From the welding arc itself.) can do it, particularly any stored Flash content is easiest to erase. Usually this is not fatal. Full metal shielding is the only protection from this.
2) But what is more likely is fault like currents in the interconnected metalwork and electrical systems. If there is an external common connection across the circuit board then you are at risk of a high current in that path, this will produce voltages on the I/O pins that can be excessive and therefore damaging. At the extreme it can even blow the tracks off the circuit board.
The typical design avoidance for this issue is to use electrical isolators like optocouplers and transformers. Usually lots of them.
What board are you using?
How is it mounted? (in a metal case etc)
What leads connect to the box?
Is the welder running off the same mains power as the Prop?
What type of power supply are you using?
If you answer that then that probably covers enough information for the moment, then there's the other 90%......
In hind sight I recall turning the system on a few occasions and it didn't boot, this never happens. It is possible the solder was at the end of it's life. So maybe this was a board fault, easy to diagnose when I get it back.
System was working for years, but one time we have a failure of the common ground to an rf power amplifier.
First thinking the amp was broken, because low rf output, and blame the propeller sending wrong commands
=> the amplifier takes partial the ground trough the propeller , >15 amps from 12 volt battery....
The propeller pcb was not powered, but trough the sensors and external connection ground, we get a lot of damage.
Eeprom dead, some pins on the propeller, total lose
Guess the grounding of the welding electrode was not always 100% to ground, and passed partial trough the grounding of you pcb....
Welding @ 125Amps ... and get some amps trough the sensors gound
Is this something they will do frequently, or was it a one-off case ?
When testing the returned board, I recall mention the PLL is more 'damage-sensitive', and you could test it with code that uses the RC osc first ?
