saving on EEPROM — Parallax Forums
saving on EEPROM
Hi Everybody. so I have a propeller mini and a propeller project board. I ran the eeprom test file in my learn folder on the project board and everything worked fine but when I try to run it on the mini nothing happens I even changed the address below 32xxx which worked fine on the project board but nothing on the mini. is there something different about the mini?
  • the only difference I see is on the SCL line, the project board has a 10k resistor on it and the mini does not. would adding one fix this problem?
    bnikkel wrote: »
    Most likely would help. That is a pullup resistor.
