Parallax Assembler or C Compiler for P24 or PX
Anybody know if there are any of these in some dusty corner of the Parallax archives
you could still get to run on a current PC?
I know there is an SX Assembler just wondering if they ever made one for higher level Stamps2's.
JUNIOR ENGINEER
AMATEUR ASSEMBLY PROGRAMMER
  • 29 Comments sorted by Date Added Votes
  • jmgjmg Posts: 10,763
    edited June 2017 Vote Up0Vote Down
    Every Microcontroller on the planet, usually has an assembler.
    The question is less about Assembler availability, and more about how to usefully get the code into the MCU.
    Any part that is not OTP, could be erased and reprogrammed with any valid code, but then you have lost what makes a Stamp, a Stamp....
    If you need ASM and a Stamp form factor, you are probably smarter to swap in a newer, better MCU into the same PCB form factor, but that is a new PCB design.
  • microcontrollerusermicrocontrolleruser Posts: 557
    Thanks.
    I'm trying to find out if they ever made these.
    I think their are a bunch of languages for the Basic Stamp.
    Or am I thinking of something else. The Javelin Stamp or something?
    JUNIOR ENGINEER
  • There's only one language for the BASIC Stamps: PBASIC.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • I will have to double check what kind of chip is underneath
    before deciding to overwrite it.
    If it is a Ubicom that would make it unusable. No language to program it in now.
    If it is a PIC C series that makes it unusable. New programmers won't program EPROM chips.
    Only worthwhile if it is a PIC F series with flash programmable memory.
    If it is kept Stamp will keep it to pull out once and a while and putter with.
    JUNIOR ENGINEER
    Note that PIC16F57 needs 12V Vpp applied to MCLR/VPP, as in http://www.microchip.com/forums/m613050.aspx
  • Thanks.
    Did not know you could program C series PIC's with a PICKit3.
    Probably keep any Stamps the way they are.
    Any circuits can be duplicated with a PIC.
    I think it's the SPIN Stamp and the Propellor that have
    other languages users have come up with.
    Probably a Basic for Progellor.
    JUNIOR ENGINEER
  • Remember that there's no going back. Once you overwrite the PBasic interpreter, you'd have to send the Stamp back to Parallax to have them restore the PBasic interpreter.
  • Mike GreenMike Green Posts: 22,592
    The Spin Stamp is just a Propeller on a Stamp pinout module (with 3.3V logic I/O ... not 5V)
    You could use C or Spin or PAsm or Forth or FemtoBasic or PropBasic
  • Mike
    Great!
    'You could use C or Spin or PAsm or Forth or FemtoBasic or PropBasic '
    Okay. Biting my tongue on any 'follow up' questions.
    JUNIOR ENGINEER
  • Mike Green wrote: »
    The Spin Stamp is no longer available. I guess the closest substitute is the PropMini.
  • David
    Thanks.
    JUNIOR ENGINEER
    David Betz wrote: »
    Why not FLiP ?
  • jmg wrote: »
    David Betz wrote: »
    Why not FLiP ?
    That would be a good choice as well but it's physically bigger than the SpinStamp/PropMini. I thought he was looking for something that was stamp sized.
  • 'looking for something that was stamp sized.'
    Not hardware. Software.
    Did Parallax ever make a C Compiler for Stamp or PIC?
    Did they ever make an Assembler for Stamp or PIC?
    What got me going was seeing an old Parallax PGM PIC programmer(hardware).
    Parallax SX Compiler is a very good piece of software.
    So is tutorial that goes with it.
    Parallax bunch in early PIC days were a sharp little bunch.
    JUNIOR ENGINEER
  • Found it!
    http://www.tech-tools.com/CVASM16.htm
    This is the outfit that bought it from Parallax.
    Tip: Will not run on Windows 7 Pro 64bit.
    I am going to install Windows 7 Pro 32bit on it's own hard drive to get it going.
    JUNIOR ENGINEER
  • JUNIOR ENGINEER
    Microchip has a C compiler and assembler for the PIC. I doubt it's even possible to make a C compiler or even an assembler for the Stamp since it runs a BASIC VM.
    David
    'BASIC VM.'
    What's that?
    How does it work please.
    Do you have some links to their C compilers. Not finding it Googling.
    JUNIOR ENGINEER
  • As far as I know, Parallax has never released a description of the VM in the BASIC Stamp. That's their "special sauce".
  • I get it now.
    ' I doubt it's even possible to make a C compiler or even an assembler for the Stamp'
    Better to you wholesale replace Basic Stamp with PIC and just use existing compilers.
    Is that Basic Stamp module dip socket PIC size?
    I have always thought it is too wide.
    JUNIOR ENGINEER
  • Here is a link to the MicroChip tools for PIC.
    http://www.microchip.com/mplab/compilers
  • MPLAB.
    This is my break from that.
    SFR's.W register.Constants. Big fun!:)
    Does not look like a PIC will fit in there.
    Width is 600ml probably like PIC16F59 40 pin and whatnot.
    24 pins? Maybe a 20 pin PIC will fit. Then there is the pinout issue.
    'Can you say Prroprietary?:)
    As of right now. No go.
    JUNIOR ENGINEER
    Any body have a link to the last known location of Parallax C Compiler for PIC?
    Maybe there is a backdoor to Basic Stamp in it.
    Reason I am looking is Parallax has a nice touch with documentation.
    With MPLAB is more of an 'Anti-touch'.
    Written like they are running scared from liability or something.
    'Our ______ wouldn't work because of what you wrote and it cost us 10's of thousands of dollar'
    Sounds like a personal problem to me.:)
    JUNIOR ENGINEER
  • Any body have a link to the last known location of Parallax C Compiler for PIC?
    Parallax never created a C compiler for the PIC. The only C compiler they've ever created as far as I know is the one I worked on for the Propeller.
  • You wrote Microchip and I was seeing Parallax.
    Yes they did make an Assembler.
    It's in that link above and it's available today but they sold it awhile ago.
    Obviously it does not say Parallax on it anymore.
    JUNIOR ENGINEER
  • The point is they could do it if they wanted to.
    In my opinion they probably should have or should now.
    MPLAB IDE's are no walk in the park.
    It's well known it's a long and steep learning curve.
    JUNIOR ENGINEER
    MPLAB.
    If you want to avoid MPLAB, there are also other assemblers.
    Google finds this
    https://board.flatassembler.net/topic.php?t=18607
    and I experimented with fasmg for P1 Opcodes, with help from the fasmg author, as it has powerful but nor-trivial macro engine.
    It is unlikely the Stamp cloned any real MCU pinout, but if you have stamp sockets out there to fill, and enough volume, you could make an equivalent PCB with your choice of MCU.
    Digikey show 13,813 active/stocked MCUs, so there are a lot to choose from ;)
    ( Some are 5V operation with USB bootloaders )
  • Snapped out of it and remember the goal here.
    Will get current Parallax Assembler running.
    It is now Tech Tools Assembler.
    Will not run on Win 7 and probably later.
    Will install Windows 2000 32 bit on it's own hard drive and see if Tech Tools runs.
    I think it is Basic and Assembler for PIC.
    Very historic.:) The ancestor of PBasic.
    JUNIOR ENGINEER
  • Conclusion:
    Just have to use Stamp Editor better Stamps: BS2e, BS2p24 and 40, BS2Pe, BS2PX
    The SX editor is the way to go for learning the most about MCU's.
    Actually a darn good product if it wasn't so old.
    JUNIOR ENGINEER
