Solved: Audio Ground Loop Problem
I think it's ground loop. Have a serial-controlled MP3 player module connected to a Veho-style mini amplified speaker. It works perfectly. BUT I'm building this into a project, and I need to change the amplifier power to the same 4.5V supply as the micro and MP3 player. So I route the + & - wires previously to the LiPo to the same 3X AA cells as powering everything else. Works but there's a high-pitch whine (only) while MP3 files are playing. Then I disconnect the - wire and there is still power and the whine is gone but there's distortion .
Anybody got a quick solution or idea?
FYI, there are right ways and wrong ways to merge stereo signals into a mono signal for an amplifier. I used this one from http://www.rane.com/note109.html and it worked fine with my LM386:
