What terminals to use for stacked boards — Parallax Forums
I'd like to stack a bunch of boards with terminal blocks on the edges of each of them. The boards are stacked with only 10mm of spacing in between them. With regular terminal blocks, the screw terminal is inaccessible once you stack the boards.
What's something that works like a terminal block except lets you adjust the tightness on the edge as well?
I was looking at Weidmueller but was wondering if there's a better solution out there?
