AUGS/AUGD queries
TonyBTonyB Posts: 73
edited 2017-04-28 - 14:47:09 in Propeller 2
I've been trying to understand AUGS/AUGD and I have a few questions. Here are the two opcodes with slightly different spacing from normal:
EEEE 11110 NNNNNNNNNNNNNNNNNNNNNNN 	AUGS    #N
EEEE 11111 NNNNNNNNNNNNNNNNNNNNNNN	AUGD    #N
1. Do AUGS/AUGD apply to all instructions that use S/D or only a few?
2. I assume N is loaded into a 23-bit register/latch used only by AUGS/AUGD and AUG flags are set, which are cleared sometime during the following instruction after the AUG address register has been read and it is safe to be interrupted. Is that correct?
3. If the address space is only 20-bit, how can a combined 32-bit address be used?
4. I have modified the opcodes above, replacing the Ns with 23 unique lower-case letters for clarity (I hope):
EEEE 11110 abcdefghijklmnopqrstuvw 	AUGS    #a...w
EEEE 11111 abcdefghijklmnopqrstuvw 	AUGD    #a...w
How are the individual abc...uvw bits combined with SSSSSSSSS or DDDDDDDDD exactly?
Are the following examples from the documentation
%000000000000AAAAAAAAAAA_AAAAAAAAA	AUGS, 20-bit immediate
%000000001SUPNNNNNNNNNNN_NNNNNNNNN	AUGS, PTRx expression
equivalent to
%000000000000mnopqrstuvw_SSSSSSSSS	AUGS, 20-bit immediate
%000000001jklmnopqrstuvw_SSSSSSSSS	AUGS, PTRx expression
If so, how or where are abcdefghi used?
  • I think AUGS/AUGD are only for use with immediate instructions. The effect of:
        AUGS #%abcd...uvw
        ADD  x, #%SSSSSSSSS
    is to add the 32 bit value %abcd...uvwSSSSSSSSS to x. It's particularly useful in HUB or LUT execution, as an easy way of generating 32 bit constants without requiring a COG register. As such, AUGS will be used a lot more often than AUGD, since more instructions have immediate sources than immediate destinations.
    AUGS is not to be confused with ALTS, which completely replaces the source field of the next instruction. It's also not usually necessary to explicitly write the AUGS, since the assembler can do it for you. The above code is the same as:
        ADD x, ##%abcd...uvwSSSSSSSSS
    where the '##' tells the assembler to emit an AUGS before the ADD in order to achieve a full 32 bit immediate.
    Eric
    FlexGUI, a GUI for programming the P1 and P2 in Spin, PASM, BASIC, and C.
    Help support its development at Patreon or PayPal.
  • Thank you, that probably answers both Q3 and Q4. I was thinking too much about addresses.
  • TonyBTonyB Posts: 73
    edited 2017-04-30 - 18:11:20
    edited 2017-04-30 - 18:11:30
  • jmgjmg Posts: 14,140
    TonyB wrote: »
    Please ignore the above, I've had a better idea.
    You cannot delete a post, but you can edit it down as small as '.'
  • To answer question #1 more precisely, an AUGx instruction gets apply to the next instruction that can use it rather than always the following instruction. Instructions that can use it are ones that have immediate (#) addressing mode only for the respective S and D operands.
    So, for example, NOP has no operands so will not consume any proceeding AUGx setup. The AUGx setup carries for a future instruction ... An AUGS #5000 preceding an ADD D,S won't consume the setup but a subsequent ADD D,#5 will add #5005 to D and consume the setup. I don't think there is any limit to the number of instructions it can carry for.
    The two AUGx's (AUGS/AUGD) themselves can both be setup without interference. I don't know if there is a special order required or they are just considered special and therefore it don't matter.
    And lastly, I think, for any hand set AUGx's in Pnut, the text values are treated as whole absolute so when converted to machine code get their bottom 9 bits trimmed. Easier to use ## instead.
    We have the vastness of the internet and yet billions of people decided to spend most of their time within a horribly designed, fake-news emporium of a website that sucks every possible piece of personal information out of you so it can sell it to others. And they see nothing wrong with that.
  • As a pointer, HubRAM read/write opcodes use S operand so again you'd want to use AUGS to set a 32-bit Hub address, branching instructions use D operand so AUGD for them to reach across large spaces in HubRAM.
    On that note, setting up HubRAM burst mode operation (RDFAST/WRFAST/FBLOCK) can nicely use both AUGS and AUGD together.
  • Would someone please define AUGS and the associated stuff for that. I cannot find what the acronym means.
    “Light thinks it travels faster than anything but it is wrong. No matter how fast light travels, it finds the darkness has always got there first, and is waiting for it.”
    “You only live twice:
    Once when you are born
    And once when you look death in the face”
  • AUGment Source
    AUGment Destination
  • msrobotsmsrobots Posts: 2,973
    edited 2019-02-14 - 16:45:52
    I had to edit this, @evanh explained me my mistake
    ALTx changes the next instruction
    AUGx extend the range of D and S of up-coming immediate fields to full 32-bit in each case. Not necessarily in the next instruction either.
    so a standard
    mov register, #value where value is a constant
    is restricted to 0-511 for value because we just have space for 9 bits
    if you have a bigger value you can use ALTS, the needed value for ALTS are the other bits.
    AUGS #(value>>9)
    mov register,#(value & 511)
    This is inconvient to write so the assembler has a short form, doing the same.
    mov register, ##value
    will create both instructions for you, notice the two # instead of one
    AUGD does the same for the destination
    ALTS sets/changes the source operant of the following instruction
    ALTD sets/changes the destination operant of the following instruction
    ALTI sets/changes the instruction part of the following instruction, keeping D and S
    This for self modifying code on the P1 you would directly change the bits in the instruction but you needed 2 instructions between changing and executing.
    On the P2 the instructions are pipelined (cached?) so the period between changing a instruction and being able to use it would take 4(8?) instructions between changing a instruction and being able to execute it.
    Thus the need for those instruction
    Enjoy!
    I am just another Code Monkey.
    A determined coder can write COBOL programs in any language. -- Author unknown.
    Press any key to continue, any other key to quit
    The key words "MUST", "MUST NOT", "REQUIRED", "SHALL", "SHALL NOT", "SHOULD", "SHOULD NOT", "RECOMMENDED", "MAY", and "OPTIONAL" in this post are to be interpreted as described in RFC 2119.
  • Mike,
    That's the ALTx instructions you're thinking of.
    AUGD and AUGS are just for extending up-coming immediate fields to full 32-bit in each case. Not necessarily in the next instruction either.
    edited 2019-02-14 - 16:47:12
    ohhshhh,
    you are right. I edited the post
    Not necessarily in the next instruction either. cool
  • Not only does the recipient of an AUGx not have to be the next instruction but it depends on full execution. In this example the AUGS is applied to the MOV, not the ADD.
    		augs	#$1211
    		xor	pa, pa		wz
    if_nz		add	pa, #1
    		mov	pa, #$31
    		call	#itoh
  • I presume the assembler duplicates the condition to the AUGx instruction when converting ## notation? In fact I'm sure it must do as I've relied on this.
    SKIP and SKIPF are presumably a minefield for combining with ## expansions, that is presumably a case where
    explicitly using AUGx is worthwhile.
  • Mark_T wrote: »
    This is why the assembler should make SKIPF masks for you.
  • evanh wrote: »
    		augs	#$1211
    		xor	pa, pa		wz
    if_nz		add	pa, #1
    		mov	pa, #$31
    		call	#itoh
    Interesting. I just had to run a program to prove this!
    Seems the AUGS will only insert into the next instruction that executes with an immediate S.
    My Prop boards: P8XBlade2 , RamBlade , CpuBlade , TriBlade
    P1 Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
    Website: www.clusos.com
    P1: Tools (Index) , Emulators (Index) , ZiCog (Z80)
    P2: Tools & Code , Tricks & Traps
  • and that is very cool. As more as I dig into PASM2 the more I like it. And I am just touching the basics right now.
    Enjoy!
  • TonyB_TonyB_ Posts: 1,350
    edited 2019-02-15 - 11:38:58
    deleted
    Formerly known as TonyB
