Making complicated decisions — Parallax Forums
Does anyone know how I would modify a or b to make it only print one message? I am working on the "make complicated decisions" part on parallax's website.
int main() // main function
int a = 17; // Initialize a variable to 25
int b = 17; // Initialize b variable to 17
print("a = %d, b = %d\n", a, b); // Print all
if((a > b) || (a == 100)) // If a > b OR A == 100
print("a might be larger than b, \n"); //Then print this message
print("OR a might be 100, \n"); //Then print this message
print("OR mabey both!\n"); //Then print this message
Thanks in advance
  • AribaAriba Posts: 2,682
    edited 2017-04-14 12:20
    You can't print only one message with certain a, b values. If the condition is true all of them get printed out, it's one block of print commands.
    If you want the messages dependent of the values, you need separate IF tests:
      if(a > b)
        print("a is larger than b, \n");
      if(a == 100)
        print("a is 100, \n");
      if((a > b) && (a == 100))
        print("both!\n");
    Andy
  • JonnyMacJonnyMac Posts: 8,918
    edited 2017-04-15 16:30
    Your first to if statements have an extra left parenthesis, Andy.
    Thank's Jon
    I have it edited
  • Ariba - don't you want some else statements and reordering so that only one is printed?
    KeithE wrote: »
    Not necessary, but the code will be slower as it has to test each if statement.
    Could also be done with a switch/case method.
  • I just mentioned it since the original post said: "make it only print one message"
