Propeller Activity Board WX (motors erratic) — Parallax Forums
bmastelbmastel Posts: 1
edited 2017-02-20 07:50 in General Discussion
When loading sample Code to Run or Download and run the right wheel doesn't listen correctly to the code. I have tried calibration without success. How do I know if I have a defective logic board?
  • ElectrodudeElectrodude Posts: 1,621
    edited 2017-02-20 06:46
    Try switching the left and right motors cables to see what happens. (Obviously, it won't drive properly like that, but this is just to find out what's wrong.) Which motors work after doing that? Does the right motor still not work, or the left one, or what?
  • Admin: moved from Propeller2 to General Discussion
  • Make sure you have the resistors in the board as well, as indicated by the Learn instructions.
    Also check you got the right and left servo, as well as right and left encoders plugged in to the correct headers.
