Golf Challenge: Cheap Simple PWM Circuit
I need a bunch of small self-contained PWM speed controllers for cheap DC brushed motors. I've been able to reduce speed a bit using my favorite trick of series dropping diodes, but that loses torque.
Picture a small 3- or 4-pin board with DC + and - in, and motor + and - out. Onboard circuit has a pot to adjust speed 0-100%. Say 3-12V. Set speed & forget. No reverse. Seems like these should be a dollar from Ebay but I can't find anything close!
Alternatively it could be a 3-pin board with standard "servo" connections: +, - and motor out (common ground).
I'm about to cobble up half a dozen by hand using the serfeit (!) of 555 timer chips I've hoarded. With the diode trick I can get below 50% PWM, and it's got a decent current rating of 200 mA, so in some cases it wouldn't even need a transistor switch.
I bet the geniuses here can think up a few alternatives. Beau & PhiPi are pretty quick with offbeat solutions.
Whaddyagot?
Whaddyagot?
EDIT - actually, the speed control pot would be the "feedback" but otherwise it would just be an open-loop PWM driver.
The SMPS module is the easy route though if you are not worried about feeding a linear voltage to the motor. Direct motor PWM overcomes stiction and allows it to run smoother at lower speeds.
If you need 12v and 200mA, the 555 is going to struggle a little, but there is little that comes close.
Older Switchmode PWM drivers could do PWM, but you need one that has sawtooth access on the pins.
If you want it to react like a servo, then you'd likely need a low cost MCU.
Cheapest self-contained MCU that is not brain-dead is the EFM8BB1 from SiLabs.
(or broadly similar but slower n79e715as16 )
Both have on board CalOsc, PWM, UART, ADC so has no problems with PWM/pot/servo side, but it does needs a regulator and transistor/fet drive for 200mA/12v
