cnt question
K2
in Propeller 1
With an instruction like:
wrlong cnt par
Will the value of cnt transferred be the value
when the instruction is encountered
or when the transfer actually takes place?
wrlong cnt par
Page 9 of the Propeller data sheet describes the execution stages.
https://www.parallax.com/sites/default/files/downloads/AN009-ExecutionTime-v1.0.pdf
Shadow: a register location on the <Left side> of a instructions, so it's not a <destination rule> as for WRLONG it may look like you're pointing to source-side-cnt
that hardware will not update the "left side version of cnt" and should just be treated as free ram.
You could do a mov cnt,cnt first if you want to send the cnt value.
The shadow register matter is a new complication. Since wrlong operates differently than other instructions, in the sense that data flows l-to-r in its specific case, I figured cnt could be used where normally a destination is specified. (I remember some interesting discussions involving shadow registers years ago. When I have time I'll look up those old posts and try to educate myself regarding that whole business.)
Anyway, I ended up doing as tony suggests: I saved the instantaneous value of cnt to a local register and then transferred it to HUB with a second instruction. Works great. Still leaves me wondering if I could have coded it better.
These below are both the same:
mov CNT,CNT 'copy value to shadow.
mov $1F1,CNT 'copy value to shadow.
The intented use of CNT is read-only, right-side/source-side only.
so the cogs hardware overrides the cogs local ram address of $1F1 when it's on the right side/source side and reach out the global system counter.
It's not hard to imagine that the left-side shadow-register just sit there dormant.
WRLONG uses it as "source" but the hardware don't override left side use of $1F1
