Is shutting down cogs OK when 8 is not enough? — Parallax Forums
My project uses seven cogs. I am using one cog to control four servos. I want to use four DC motors instead of four servos to control a robotic arm. By attaching a pot to a motor I can control it like a servo but I can only control one motor per cog. The problem I have with multiple dc motors is controlling overshoot.
One solution would be to experiment with PASM. The second idea is to control two motors with two cogs at a time. I'm tying up both counters to control motor speed so I'd have to reinitialize the counters each time I switched motors. Is this advisable?
My goal is to scale this thing up so I can make it do useful work.
    Not enough info in your post for a definitive answer, but it would depend on how much processing needs to be done for controlling each motor. I would look at the calculations to see if a cog has enough memory for the code and variables needed for the four motors.
  • What sort of resolution and frequency to these motors need?
    There are a variety of PASM PWM drivers for use with multiple motors.
    I'm pretty sure I have a PWM driver which produces four signals from a single cog (I have one which also reads four quadrature encoders with the same cog).
    If you describe your requirements in more detail, I bet we could help you find an appropriate driver.
  • Duane Degn wrote: »
    The motors don't need much resolution. I'm using Chip's mcp3208 driver and I set it to return 0 to 63. The concept and the code is simple. I rotate a potentiometer and then the motor, which is also connected to a pot, rotates until it matches the value I sent it. It works well. If there's just one motor I can also adjust the pwm duty cycle and avoid problems with the motor overshooting the commanded position.
    This is what it looks like:
    Repeat
          MyPot := ptest.get_temp1
          MotorPot := ptest.get_temp2
          If MyPot > MotorPot
            main(3000, 0)
          elseif MyPot <  MotorPot
            main(0, 3000)
          elseif MyPot ==  MotorPot
            main(0, 0)
    When I tried testing two motors I could see that this approach didn't work.
    One cog running a PASM version of that simple program using integer math should easily handle 4 motors, particularly if you take advantage of the high speed MCP3208 object.
    If needed it could even be modified to decelerate as the motors approach the desired position.
    edited 2016-11-29 19:37
    lardom wrote: »
  • User Name wrote: »
    I'm just about ready to tackle my first pasm project. The newest thing for me is "flags". I'll start off with small test code.
  • lardom wrote: »
    Based on the above statements, if budget will allow it, I would suggest closing the servo-loops with incremental encoders (like real robots). With only one cog available, you might want to consider motion control co-processors via RS485, such as:
    http://www.jrkerr.com/icproducts.html
  • @Mickster, Thanks, I bookmarked the page.
