LORA — Parallax Forums
LORA
I use a propeller C3 with a mdot of multitech. I use Rx and Tx pin for the communication.
The mdot's settings is attached (mdot's settings)
My code is the following :
CON
' PROP CHIP / SYSTEM DEFINES //////////////////////////////////////////////////
  ' These settings are for 5 MHZ XTALS
  _clkmode = xtal1 + pll16x         ' enable external clock and pll times 16
  _xinfreq = 5_000_000              ' set frequency to 5 MHZ
  rxPin = 0
  txPin = 2
  mode = %0000
  baudrate = 9600
  relaiRouge = 3
  relaiJaune = 1
  Temps_attente = 3000
VAR
  byte char, char1, ptr, ptr1, ptr2, AT_Reponse[200], AT_Reponse1[200], RSSI[200], SNR[200], nombre_recu
  long data1, data2, data3
OBJ
  pst : "Parallax Serial Terminal"
  LORA : "FullDuplexserial"
PUB main
  pst.Start(115200)
  LORA.Start(rxPin, txPin, mode, baudrate)
  data1 := 200
  data2 := 1200
  data3 := 2200
  dira[relaiRouge] := 1
  dira[relaiJaune] := 1
  outa[relaiRouge] := 0
  outa[relaiJaune] := 0
  waitcnt(clkfreq*2+cnt)
  pst.str(String("launching: ",9))
  LORA.str(String("at",13))
  repeat 3
    Rx(Temps_attente)
    pst.Str(String(13))
    pst.str(String("at command: ",9))
    pst.str(@AT_Reponse)
    pst.Str(String(13))
  waitcnt(clkfreq+cnt)
  LORA.str(String("at&v",13))
  repeat 49
    Rx(Temps_attente)
    pst.Str(String(13))
    pst.str(String("at&v command: ",9))
    pst.Str(@AT_Reponse)
    pst.Str(String(13))
    LORA.str(String("at+fsb=0",13))
  repeat 3
    Rx(Temps_attente)
    pst.Str(String(13))
    pst.str(String("at+fsb command: ",9))
    pst.Str(String(13))
    LORA.str(String("at+ni=1,conduit123",13))
  repeat 3
    Rx(Temps_attente)
    pst.Str(String(13))
    pst.str(String("at+ni command: ",9))
    pst.Str(String(13))
  LORA.str(String("at+nk=1,conduit123",13))
  repeat 3
    Rx(Temps_attente)
    pst.Str(String(13))
    pst.str(String("at+nk command: ",9))
    pst.Str(String(13))
  LORA.str(String("at+join",13))
  repeat 3
    Rx(Temps_attente)
    pst.Str(String(13))
    pst.str(String("at+join command: ",9))
    pst.Str(String(13))
  repeat
    repeat 5
      LORA.Str(String("at+send="))
      LORA.Dec(data1)
      LORA.Str(String("&RSSI="))
      LORA.Dec(data2)
      LORA.Str(String("&SNR="))
      LORA.Dec(data3)
      LORA.Str(String(13))
      repeat 3
        Rx(Temps_attente)
        pst.Str(String(13))
        pst.str(String("at+send command: ",9))
        pst.Str(String(13))
        if (data1 > 1000)
          outa[relaiJaune] := 1
            if (data1 > 2000)
               outa[relaiRouge] :=1
    repeat 5
      LORA.Dec(data2)
      repeat 3
        Rx(Temps_attente)
        pst.Str(String(13))
        pst.Str(String(13))
        if (data2 > 1000)
            if (data2 > 2000)
    repeat 5
      LORA.Dec(data3)
      repeat 3
        Rx(Temps_attente)
        pst.Str(String(13))
        pst.Str(String(13))
        if (data3 > 1000)
            if (data3 > 2000)
    repeat 5
      LORA.Dec(data2)
      repeat 3
        Rx(Temps_attente)
        pst.Str(String(13))
        pst.Str(String(13))
        if (data2 > 1000)
            if (data2 > 2000)
    repeat 5
      LORA.Dec(data1)
      repeat 3
        Rx(Temps_attente)
        pst.Str(String(13))
        pst.Str(String(13))
        if (data1 > 1000)
            if (data1 > 2000)
  '    waitcnt(clkfreq+cnt)
PUB Rx(timeout)
  Rx_LORA(timeout)
Pub Rx_LORA(timeout)
    ptr := 0
    if (nombre_recu == 0 OR nombre_recu == 2)
      LORA.RxFlush
      repeat
        char := LORA.Rx
        AT_Reponse[ptr++] := Char
      while (char <> 13)
      AT_Reponse[--ptr] := 0
    elseif (nombre_recu ==1)
      LORA.RxFlush
      repeat
        char := LORA.Rx
        AT_Reponse1[ptr++] := Char
      while (char <> 13)
      AT_Reponse1[--ptr] := 0
    else
      abort
In the first time, I don't understand why I not receive the first character of my response and sometimes the first two characters (three image that is attached (first, second and third part)) .
If anyone has a hint, I would appreciate
483 x 709 - 23K
1119 x 917 - 33K
1123 x 921 - 32K
1123 x 582 - 21K
