PropBasic jm_ir_hdserial header
Rsadeika
in Propeller 1
I am considering a driver for using the IR, found on the Hackable Badge and QuickStart HIB board. Since their are a few PropBasic programmers here, which way would be the best way to accomplish this?
I found a Spin program that JonnyMac has developed, which has an PASM component and a Spin component. Using that as a reference, which approach is the best. From the jm_ir_hdserial.spin code, it looks like maybe taking the PASM section and trying to fit it in the PropBasic format would be a consideration, not sure about that though. Any ideas as to how to approach this? Of course this would be a lib file so it could be added/used in other PropBasic programs.
Ray
Ray
{ ----------------------------- } { I R U A R T D R I V E R } { ----------------------------- } dat { ir uart } org 0 irhds mov t1, par ' start of structure mov rxheadpntr, t1 ' save hub address of rxhead add t1, #4 mov rxtailpntr, t1 ' save hub address of rxtail add t1, #4 rdlong rxbufpntr, t1 ' read address of rxbuf[0] add t1, #4 mov txheadpntr, t1 ' save hub address of txhead add t1, #4 mov txtailpntr, t1 ' save hub address of txtail add t1, #4 rdlong txbufpntr, t1 ' read address of txbuf[0] add t1, #4 rdlong t2, t1 ' get rxpin mov rxmask, #1 ' make pin mask shl rxmask, t2 andn dira, rxmask ' force to input add t1, #4 rdlong t2, t1 ' get txpin mov txmask, #1 ' make pin mask shl txmask, t2 andn dira, txmask ' disable modulation add t1, #4 rdlong bit1x0tix, t1 ' read 1.0 bit timing mov bit1x5tix, bit1x0tix ' create 1.5 bit timing shr bit1x5tix, #1 add bit1x5tix, bit1x0tix add t1, #4 ' get mod frequency rdlong frqa, t1 ' setup ctra modulation or t2, NCO_SE ' on tx pin mov ctra, t2 ' activate counter ' ========= ' RECEIVE ' ========= rxserial mov rxtimer, cnt ' start timer test rxmask, ina wc ' look for start bit if_c jmp #txserial ' if no start, check tx receive add rxtimer, bit1x5tix ' skip start bit mov rxwork, #0 ' clear work var mov rxcount, #8 ' rx 8 bits rxbyte waitcnt rxtimer, bit1x0tix ' wait for middle of bit test rxmask, ina wc ' rx --> c shr rxwork, #1 ' prep for next bit muxc rxwork, #%1000_0000 ' add bit tor rxwork djnz rxcount, #rxbyte waitcnt rxtimer, #0 ' let last bit finish test rxmask, ina wc ' verify stop bit if_nc jmp #txserial ' skip if bad IR input putrxbuf rdlong t1, rxheadpntr ' t1 := rxhead add t1, rxbufpntr ' t1 := rxbuf[rxhead] wrbyte rxwork, t1 ' rxbuf[rxhead] := rxwork sub t1, rxbufpntr ' t1 := rxhead add t1, #1 ' inc t1 and t1, #BUF_MASK ' rollover if needed wrlong t1, rxheadpntr ' rxhead := t1 ' ========== ' TRANSMIT ' ========== txserial rdlong t1, txheadpntr ' t1 = txhead rdlong t2, txtailpntr ' t2 = txtail cmp t1, t2 wz ' byte(s) to tx? if_z jmp #rxserial ' check rx gettxbuf mov t1, txbufpntr ' t1 := @txbuf[0] add t1, t2 ' t1 := @txbuf[txtail] rdbyte txwork, t1 ' txwork := txbuf[txtail] updatetxtail add t2, #1 ' inc txtail and t2, #BUF_MASK ' wrap to 0 if necessary wrlong t2, txtailpntr ' save transmit or txwork, STOP_BITS ' set stop bit(s) shl txwork, #1 ' add start bit mov txcount, #11 ' start + 8 data + 2 stop mov txtimer, bit1x0tix ' load bit timing add txtimer, cnt ' sync with system counter txbit shr txwork, #1 wc ' move bit0 to C muxnc dira, txmask ' enable modulation if C == 0 waitcnt txtimer, bit1x0tix ' let timer expire, reload djnz txcount, #txbit ' update bit count jmp #txserial ' ------------------------------------------------------------------------------------------------- NCO_SE long %00100 << 26 ' S/E NCO mode STOP_BITS long $FFFF_FF00 rxheadpntr res 1 ' head pointer rxtailpntr res 1 ' tail pointer rxbufpntr res 1 ' hub address of rxbuf[0] txheadpntr res 1 ' head pointer txtailpntr res 1 ' tail pointer txbufpntr res 1 ' hub address of txbuf[0] rxmask res 1 ' rx pin mask txmask res 1 ' tx pin mask bit1x0tix res 1 ' 1.0 bit timing bit1x5tix res 1 ' 1.5 bit timing rxwork res 1 ' rx byte in rxcount res 1 ' bits to receive rxtimer res 1 ' timer for bit sampling txwork res 1 ' tx byte out txcount res 1 ' bits to transmit txtimer res 1 ' timer for bit output t1 res 1 ' work vars t2 res 1 t3 res 1 fit 496
Receiving is the same everywhere. To transmit IR, you need to assign one of the counters to the TX pin and set it to run as an oscillator for your modulation frequency. When you want to output a start or "0" bit, enable the output driver for the TX pin.
Easy peasy.
