Setting output bits in Pasm — Parallax Forums
Hello readers of the forum.
I have a question about setting output bits in Pasm. When i set or reset 1 bit I use the example in Part_1 of my code snippet below. But when I want to set more bit's, but stil not touch other bit's, I use the code snippet of Part_2. Are I am right, is this the right way or is there an other way to set/reset for example a nibble to the output pin's in Pasm.
Greeting Abraham
dat
'example data = %00000000_00000000_00001010_00000000 or %00000000_00000000_00001101_00000000
Start         mov       dira,   Pin_out         ' Set the output's
Part_1        or        outa,   Clk_2           ' Set a bit
              andn      outa,   Clk_2           ' Reset a bit
Part_2        andn      outa,   mask_nibb       ' Clear a nibble
              or        outa,   data            ' Set data nibble
Pin_out    long         %00000000_00011111_11111111_00000000
Clk_2      long         %00000000_00010000_00000000_00000000
mask_nibb  long         %00000000_00000000_00001111_00000000
  • ElectrodudeElectrodude Posts: 1,621
    edited 2016-08-22 17:56
    That's the usual way to do it on the P1.
    You can also use "or" and "andn" to modify dira if you need to change pin directions at runtime, but a "mov dira, whatever" is fine for setup.
    edited 2016-08-22 18:49
    Your Part_2 code will cause a glitch on the pins you're trying to change. If that's not acceptable, you can do this instead:
    Part_2        mov       temp,outa
                  andn      temp,mask_nibb       ' Clear a nibble
                  or        temp,data            ' Set data nibble
                  mov       outa,temp
  • Your Part_2 code will cause a glitch on the pins you're trying to change. If that's not acceptable, you can do this instead:
                  mov       outa,temp
    Phil.
    Thanks for this suggestion. I go use it.
    Abraham.
  • Phil:
    Thanks for pointing out the glitching problem with the original Part_2 code. That pointed out a fastspin bug; the optimizer wasn't special casing OUTA or DIRA, and so the code generated did look like that original one. I've added a special case for OUTA[a..b] and DIRA[a..b] to use the second form, so it's fixed in fastspin 3.1.2.
    Eric
