SLAM using the XV-11 Neato robotics LiDAR. — Parallax Forums
Patrick ColemanPatrick Coleman Posts: 43
edited 2016-07-25 18:14 in Robotics
Has anyone developed a "half-way capable" SLAM model using basic arduino or propeller systems ?
Im trying to build a ground bot first, then an air bot, but navigating and automatic collision avoidance seems unavoidable for our robots to rise to any greater potential. Using LiDAR seems the only way to do this.
I found this http://diydrones.com/profiles/blogs/xv-11-lidar-copter but it seems he has two crossed lidars that dont rotate.
The above vid shows my drone with the XV-11 lidar onboard, but its not capturing data yet, just a test flight for balance.
Ive personally witnessed the effective use of LiDAR and the less effective optical flow method seen above, odometry doesn't seem useful.
Theres wiki: https://en.wikipedia.org/wiki/Simultaneous_localization_and_mapping
OpenSLAM site: http://openslam.org/
Ive been looking at the OpenSLAM site "tinySLAM" which is 200 lines of C supposedly. Id like to start with a primitive but testable version.
Thank you,
Patrick
  • Hi, interesting project. I'm a real robotics noob, but have you looked at something like this? scanse.io
    We helped back the Kickstarter and are looking forward to playing with it when it comes in a few months. Not sure, but would it work any better than the other method you linked to?
  • ive seen that one, but $255 its quite a bit, you can buy several $200 to 600 versions by various companies that are pretty good, they seem to stay in that price range. But that limits using them.
    there is also this one : http://www.robotshop.com/en/pulsedlight.html they're also working on a rotating version that will be cheap. so im not in a hurry to spend $255.
    $100 or less with a SLAM code example would be a game changer through out robotics.
