Modbus Protocol
Dear all.
I have the c++ code for Arduino Uno modbus protocol. can someone help me to convert the code c ++ to c.
void Modbus::get_FC3() {
  uint8_t u8byte, i;
  u8byte = 3;
  for (i = 0; i < au8Buffer[ 2 ] / 2; i++) {
    au16regs[ i ] = word(
    au8Buffer[ u8byte ],
    au8Buffer[ u8byte + 1 ]);
    u8byte += 2;
int8_t Modbus::process_FC1( uint16_t *regs, uint8_t u8size ) {
  uint8_t u8currentRegister, u8currentBit, u8bytesno, u8bitsno;
  uint8_t u8CopyBufferSize;
  uint16_t u16currentCoil, u16coil;
  // get the first and last coil from the message
  uint16_t u16StartCoil = word( au8Buffer[ ADD_HI ], au8Buffer[ ADD_LO ] );
  uint16_t u16Coilno = word( au8Buffer[ NB_HI ], au8Buffer[ NB_LO ] );
  // put the number of bytes in the outcoming message
  u8bytesno = (uint8_t) (u16Coilno / 8);
  if (u16Coilno % 8 != 0) u8bytesno ++;
  au8Buffer[ ADD_HI ]  = u8bytesno;
  u8BufferSize         = ADD_LO;
  // read each coil from the register map and put its value inside the outcoming message
  u8bitsno = 0;
  for (u16currentCoil = 0; u16currentCoil < u16Coilno; u16currentCoil++) {
    u16coil = u16StartCoil + u16currentCoil;
    u8currentRegister = (uint8_t) (u16coil / 16);
    u8currentBit = (uint8_t) (u16coil % 16);
    bitWrite(
    au8Buffer[ u8BufferSize ],
    u8bitsno,
    bitRead( regs[ u8currentRegister ], u8currentBit ) );
    u8bitsno ++;
    if (u8bitsno > 7) {
      u8bitsno = 0;
      u8BufferSize++;
  // send outcoming message
  if (u16Coilno % 8 != 0) u8BufferSize ++;
  u8CopyBufferSize = u8BufferSize +2;
  sendTxBuffer();
  return u8CopyBufferSize;
int8_t Modbus::process_FC3( uint16_t *regs, uint8_t u8size ) {
  uint8_t u8StartAdd = word( au8Buffer[ ADD_HI ], au8Buffer[ ADD_LO ] );
  uint8_t u8regsno = word( au8Buffer[ NB_HI ], au8Buffer[ NB_LO ] );
  uint8_t i;
  au8Buffer[ 2 ]       = u8regsno * 2;
  u8BufferSize         = 3;
  for (i = u8StartAdd; i < u8StartAdd + u8regsno; i++) {
    au8Buffer[ u8BufferSize ] = highByte(regs[i]);
    u8BufferSize++;
    au8Buffer[ u8BufferSize ] = lowByte(regs[i]);
    u8BufferSize++;
  sendTxBuffer();
int8_t Modbus::process_FC5( uint16_t *regs, uint8_t u8size ) {
  uint8_t u8currentRegister, u8currentBit;
  uint16_t u16coil = word( au8Buffer[ ADD_HI ], au8Buffer[ ADD_LO ] );
  // point to the register and its bit
  // write to coil
  bitWrite(
  u8currentBit,
  au8Buffer[ NB_HI ] == 0xff );
  // send answer to master
  u8BufferSize = 6;
  sendTxBuffer();
int8_t Modbus::process_FC6( uint16_t *regs, uint8_t u8size ) {
  uint8_t u8add = word( au8Buffer[ ADD_HI ], au8Buffer[ ADD_LO ] );
  uint16_t u16val = word( au8Buffer[ NB_HI ], au8Buffer[ NB_LO ] );
  regs[ u8add ] = u16val;
  // keep the same header
  u8BufferSize         = RESPONSE_SIZE;
  sendTxBuffer();
int8_t Modbus::process_FC15( uint16_t *regs, uint8_t u8size ) {
  uint8_t u8currentRegister, u8currentBit, u8frameByte, u8bitsno;
  boolean bTemp;
  u8bitsno = 0;
  u8frameByte = 7;
    bTemp = bitRead(
    au8Buffer[ u8frameByte ],
    u8bitsno );
    bitWrite(
    u8currentBit,
    bTemp );
    u8bitsno ++;
    if (u8bitsno > 7) {
      u8bitsno = 0;
      u8frameByte++;
  // it's just a copy of the incomping frame until 6th byte
  u8BufferSize         = 6;
  sendTxBuffer();
int8_t Modbus::process_FC16( uint16_t *regs, uint8_t u8size ) {
  uint8_t u8func = au8Buffer[ FUNC ];  // get the original FUNC code
  uint8_t u8StartAdd = au8Buffer[ ADD_HI ] << 8 | au8Buffer[ ADD_LO ];
  uint8_t u8regsno = au8Buffer[ NB_HI ] << 8 | au8Buffer[ NB_LO ];
  uint8_t i;
  uint16_t temp;
  // build header
  au8Buffer[ NB_HI ]   = 0;
  au8Buffer[ NB_LO ]   = u8regsno;
  // write registers
  for (i = 0; i < u8regsno; i++) {
    temp = word(
    au8Buffer[ (BYTE_CNT + 1) + i * 2 ],
    au8Buffer[ (BYTE_CNT + 2) + i * 2 ]);
    regs[ u8StartAdd + i ] = temp;
  sendTxBuffer();
  • other part of c++ code
    [code]
    int8_t Modbus::query( modbus_t telegram ) {
      uint8_t u8regsno, u8bytesno;
      if (u8id != 0) return -2;
      if (u8state != COM_IDLE) return -1;
      if ((telegram.u8id == 0) || (telegram.u8id > 247)) return -3;
      au16regs = telegram.au16reg;
      // telegram header
      au8Buffer[ ID ]         = telegram.u8id;
      au8Buffer[ FUNC ]       = telegram.u8fct;
      au8Buffer[ ADD_HI ]     = highByte(telegram.u16RegAdd );
      au8Buffer[ ADD_LO ]     = lowByte( telegram.u16RegAdd );
      switch ( telegram.u8fct ) {
      case MB_FC_READ_COILS:
      case MB_FC_READ_DISCRETE_INPUT:
      case MB_FC_READ_REGISTERS:
      case MB_FC_READ_INPUT_REGISTER:
        au8Buffer[ NB_HI ]      = highByte(telegram.u16CoilsNo );
        au8Buffer[ NB_LO ]      = lowByte( telegram.u16CoilsNo );
        u8BufferSize = 6;
        break;
      case MB_FC_WRITE_COIL:
        au8Buffer[ NB_HI ]      = ((au16regs[0] > 0) ? 0xff : 0);
        au8Buffer[ NB_LO ]      = 0;
        u8BufferSize = 6;
        break;
      case MB_FC_WRITE_REGISTER:
        au8Buffer[ NB_HI ]      = highByte(au16regs[0]);
        au8Buffer[ NB_LO ]      = lowByte(au16regs[0]);
        u8BufferSize = 6;
        break;
      case MB_FC_WRITE_MULTIPLE_COILS:
        u8regsno = telegram.u16CoilsNo / 16;
        u8bytesno = u8regsno * 2;
        if ((telegram.u16CoilsNo % 16) != 0) {
          u8bytesno++;
          u8regsno++;
        au8Buffer[ NB_LO + 1 ]    = u8bytesno;
        u8BufferSize = 7;
        u8regsno = u8bytesno = 0; // now auxiliary registers
        for (uint16_t i = 0; i < telegram.u16CoilsNo; i++) {
        break;
      case MB_FC_WRITE_MULTIPLE_REGISTERS:
        au8Buffer[ NB_LO + 1 ]    = (uint8_t) ( telegram.u16CoilsNo * 2 );
        u8BufferSize = 7;
          au8Buffer[ u8BufferSize ] = highByte( au16regs[ i ] );
          u8BufferSize++;
          au8Buffer[ u8BufferSize ] = lowByte( au16regs[ i ] );
          u8BufferSize++;
        break;
      sendTxBuffer();
      u8state = COM_WAITING;
      return 0;
    int8_t Modbus::poll() {
      // check if there is any incoming frame
      uint8_t u8current = port->available();
      if (millis() > u32timeOut) {
        u8state = COM_IDLE;
        u16errCnt++;
        return 0;
      if (u8current == 0) return 0;
      // check T35 after frame end or still no frame end
      if (u8current != u8lastRec) {
        u8lastRec = u8current;
        u32time = millis() + T35;
        return 0;
      if (millis() < u32time) return 0;
      // transfer Serial buffer frame to auBuffer
      u8lastRec = 0;
      int8_t i8state = getRxBuffer();
      if (i8state < 7) {
        u8state = COM_IDLE;
        u16errCnt++;
        return i8state;
      // validate message: id, CRC, FCT, exception
      uint8_t u8exception = validateAnswer();
      if (u8exception != 0) {
        u8state = COM_IDLE;
        return u8exception;
      // process answer
      switch ( au8Buffer[ FUNC ] ) {
        // call get_FC1 to transfer the incoming message to au16regs buffer
       // get_FC1( );
        break;
      case MB_FC_READ_REGISTERS :
        // call get_FC3 to transfer the incoming message to au16regs buffer
        get_FC3( );
        break;
      case MB_FC_WRITE_REGISTER :
      case MB_FC_WRITE_MULTIPLE_REGISTERS :
        // nothing to do
        break;
      default:
        break;
      u8state = COM_IDLE;
      return u8BufferSize;
    int8_t Modbus::poll( uint16_t *regs, uint8_t u8size ) {
      au16regs = regs;
      u8regsize = u8size;
        return 0;
      u8lastRec = 0;
      if (i8state < 7) return i8state;
      // check slave id
      if (au8Buffer[ ID ] != u8id) return 0;
      // validate message: CRC, FCT, address and size
      uint8_t u8exception = validateRequest();
      if (u8exception > 0) {
        if (u8exception != NO_REPLY) {
          buildException( u8exception );
          sendTxBuffer();
        return u8exception;
      u32timeOut = millis() + long(u16timeOut);
      // process message
        return process_FC1( regs, u8size );
        break;
        return process_FC3( regs, u8size );
        break;
        return process_FC5( regs, u8size );
        break;
        return process_FC6( regs, u8size );
        break;
        return process_FC15( regs, u8size );
        break;
        return process_FC16( regs, u8size );
        break;
      default:
        break;
    void Modbus::init(uint8_t u8id, uint8_t u8serno, uint8_t u8txenpin) {
      this->u8id = u8id;
      this->u8serno = (u8serno > 3) ? 0 : u8serno;
      this->u8txenpin = u8txenpin;
      this->u16timeOut = 1000;// intially set for 1000
    int8_t Modbus::getRxBuffer() {
      boolean bBuffOverflow = false;
      if (u8txenpin > 1) digitalWrite( u8txenpin, LOW );
      u8BufferSize = 0;
      while ( port->available() ) {
        au8Buffer[ u8BufferSize ] = port->read();
        u8BufferSize ++;
        if (u8BufferSize >= MAX_BUFFER) bBuffOverflow = true;
      u16InCnt++;
      if (bBuffOverflow) {
        u16errCnt++;
        return ERR_BUFF_OVERFLOW;
      u32timeOut=500;
       // u32timeOut = millis() + (unsigned long) u16timeOut;
    void Modbus::sendTxBuffer() {
      uint8_t i = 0;
      // append CRC to message
      uint16_t u16crc = calcCRC( u8BufferSize );
      au8Buffer[ u8BufferSize ] = u16crc >> 8;
      u8BufferSize++;
      au8Buffer[ u8BufferSize ] = u16crc & 0x00ff;
      u8BufferSize++;
      // set RS485 transceiver to transmit mode
      if (u8txenpin > 1) {
        switch ( u8serno ) {
    #if defined(UBRR1H)
        case 1:
          UCSR1A = UCSR1A | (1 << TXC1);
          break;
    #endif
    #if defined(UBRR2H)
        case 2:
          UCSR2A = UCSR2A | (1 << TXC2);
          break;
    #endif
    #if defined(UBRR3H)
        case 3:
          UCSR3A = UCSR3A | (1 << TXC3);
          break;
    #endif
        case 0:
        default:
          UCSR0A = UCSR0A | (1 << TXC0);
          break;
        digitalWrite( u8txenpin, HIGH );
      // transfer buffer to serial line
      port->write( au8Buffer, u8BufferSize );
      // keep RS485 transceiver in transmit mode as long as sending
    #if defined(UBRR1H)
        case 1:
          while (!(UCSR1A & (1 << TXC1)));
          break;
    #endif
    #if defined(UBRR2H)
        case 2:
          while (!(UCSR2A & (1 << TXC2)));
          break;
    #endif
    #if defined(UBRR3H)
        case 3:
          while (!(UCSR3A & (1 << TXC3)));
          break;
    #endif
        case 0:
        default:
          while (!(UCSR0A & (1 << TXC0)));
          break;
        // return RS485 transceiver to receive mode
      port->flush();
      u8BufferSize = 0;
      // set time-out for master
     u32timeOut=500;
      // increase message counter
      u16OutCnt++;
    uint16_t Modbus::calcCRC(uint8_t u8length) {
      unsigned int temp, temp2, flag;
      temp = 0xFFFF;
      for (unsigned char i = 0; i < u8length; i++) {
        temp = temp ^ au8Buffer[i];
        for (unsigned char j = 1; j <= 8; j++) {
          flag = temp & 0x0001;
          temp >>= 1;
          if (flag)
            temp ^= 0xA001;
      // Reverse byte order.
      temp2 = temp >> 8;
      temp = (temp << 8) | temp2;
      temp &= 0xFFFF;
      // the returned value is already swapped
      // crcLo byte is first & crcHi byte is last
      return temp;
    uint8_t Modbus::validateRequest() {
      // check message crc vs calculated crc
      uint16_t u16MsgCRC =
        ((au8Buffer[u8BufferSize - 2] << 8)
        | au8Buffer[u8BufferSize - 1]); // combine the crc Low & High bytes
      if ( calcCRC( u8BufferSize - 2 ) != u16MsgCRC ) {
        u16errCnt ++;
        return NO_REPLY;
      // check fct code
      boolean isSupported = false;
      for (uint8_t i = 0; i < sizeof( fctsupported ); i++) {
        if (fctsupported[i] == au8Buffer[FUNC]) {
          isSupported = 1;
          break;
      if (!isSupported) {
        u16errCnt ++;
        return EXC_FUNC_CODE;
      // check start address & nb range
     // uint16_t u16regs = 4000;
     uint16_t u16regs = 0;
      uint8_t u8regs;
        u16regs = word( au8Buffer[ ADD_HI ], au8Buffer[ ADD_LO ]) / 16;
        u16regs += word( au8Buffer[ NB_HI ], au8Buffer[ NB_LO ]) / 16;
        u8regs = (uint8_t) u16regs;
        if (u8regs > u8regsize) return EXC_ADDR_RANGE;
        break;
        break;
        u16regs = word( au8Buffer[ ADD_HI ], au8Buffer[ ADD_LO ]);
        break;
      case MB_FC_READ_INPUT_REGISTER :
        u16regs += word( au8Buffer[ NB_HI ], au8Buffer[ NB_LO ]);
        break;
      return 0; // OK, no exception code thrown
    uint8_t Modbus::validateAnswer() {
        u16errCnt ++;
        return NO_REPLY;
      // check exception
      if ((au8Buffer[ FUNC ] & 0x80) != 0) {
        u16errCnt ++;
        return ERR_EXCEPTION;
      // check fct code
          isSupported = 1;
          break;
      if (!isSupported) {
        u16errCnt ++;
    void Modbus::buildException( uint8_t u8exception ) {
      au8Buffer[ ID ]      = u8id;
      au8Buffer[ FUNC ]    = u8func + 0x80;
      au8Buffer[ 2 ]       = u8exception;
      u8BufferSize         = EXCEPTION_SIZE;
    [/code]
  • No easy fix but check your modifiers that call it out as code. This is because we are not suppose to see the BBCode things.
