Chip
In the included code which generates a VGA image if I include the COGATN instruction it randomly fails after a F11 download from Pnut.
If I remove the COGATN instruction it downloads OK every time.
What are the symptoms that it's gone wrong? I haven't yet hooked up a VGA monitor, but the upload on my A9 appears to work fine (and GRN7 is blinking).
The CALLD, with D = <any register>, S = IRETx, and WC,WZ, signals the cog that the interrupt is complete. This
causes the cog to clear its internal interruptbusy
flag for that interrupt, so that another interrupt can occur. INB
(readonly)
is used as D for RETIx instructions to effectively make the CALLD into a JMP back to the interrupted
code. Instead of using RETIx, though, you could use ‘CALLD IJMPx,IRETx WC,WZ’ to have your ISR resume at
the next instruction when the next interrupt occurs
One question is: What would happen if the video driver was somehow being loaded into Cog #1 instead of, I presume, Cog#0? Would the COGATN#1 interfere with those Streamer events?
What will the other Cog do if it never receives it's attention event?
With the current FPGA images that support the DAC's they are only accessable from Cog #0.
In the above code the COGATN is only half of the attention mechanism.
I hadn't got to the fun part of polling it yet from another cog.
Chip
The code appears to hang at the COGATN instruction which explains the no video output symptom.
I think the issue is a conflict between the interrupt driven video driver and COGATN.
If I modify the driver to run without interrupts the code runs fine and COGATN works nicely.
When I put cogatn into Chip's ntsc_256_interrupt.spin inside the field loop, it seems fine: 10 out of 10.
I'm not setup for VGA right now. Try substituting a nop for your cogatn and leave the interrupts as they were... timing issue?
In looking at the code and trying it out, I found the problem:
xcont #10,#0 'do streamer instruction to start interrupt sequence
...needs to become something like...
xcont #100,#0 'do streamer instruction to start interrupt sequence
You were just running out of time to do the first XCONT before the streamer buffer fully emptied, then requiring TWO, not just one, XCONT to carry on the show.
So that works ok on a 2 COG build, because there is less latency ?
Which raises other questions...
Why did the code break on the latest build, or was it just noticed on the latest build ?
Why is there this effect " it failed 5 times in 20 downloads." ?
Is reset exit not always the same ? - ie can something download does, vary how P2 exists from reset ?
It was right on the edge. If you change that #10 to #9, it fails every time. Lower-slice versions have lower latency which get them into the safe zone, in the case of this software example. The reason there is any uncertainty, at all, is probably due to serial receiving in relation to the egg beater. There is no bug here, just software cutting timing too close.
... The reason there is any uncertainty, at all, is probably due to serial receiving in relation to the egg beater...
I wonder how that " it failed 5 times in 20 downloads" varies over many resets, of the same download ?
Ideally, you want every reset exit to be the same, and to have no dice effects, as bugs that (eg) vary with download, but not reset, are much harder to find.
No video output but background code runs oK.
Thanks for conveying this problem.
I just ran the P123-A9 again and it failed 5 times in 20 downloads.
Fails ~1 in 5 downloads.
What is the RESI1 instruction?
Next question is: What happens if that event is set more often? Does the chance of the wrong Cog being loaded also occur more often?
It never is loaded anywhere else.
Change the line to COGATN #%10 instead and see if that works. As you have it now, the cog is setting its own ATN flag.
No. All a cog sees is the event that's set by the logical-or of the associated COGATN bit from all of the other cogs (including itself, I'm guessing).
Note that most events/interrupts have been renumbered. Be sure to use the latest documentation.
