using muliple cogs regarding Org Fit and Res — Parallax Forums
Hello,
I am working with multiple cogs in assembly, and have some questions on org,fit and res
basically where to place the fit org and res
when i run this code only two of the outputs work (two cogs output)
should the org offset for each cog like org 0 for the first, org 496 for the second and so on, should fit be at the end of each assembly routine, prior to the next org
and since the variables are accessable to all three should all the variables be assigned in the last cog start, does it matter where i place the res
anyway, I included the code
thanks in advance.
regards
Jeff
CON
  _CLKMODE = xtal1 + pll16x
  _XINFREQ = 6_200_000
VAR
long routine1_cog, routine2_cog
long  synctime1                'global var for both cogs
long  synctime2                'global var for both cogs
long  synctime3                'global var for both cogs
OBJ
  pst  : "Parallax Serial Terminal"
PUB main  : tm
     pst.Start(57_600)
     waitcnt((clkfreq*1) + cnt)
     pst.Str(String("Starting Cog ..... ",pst#NL))
   '  waitcnt((clkfreq*2) + cnt)
     'synctime := CNT + 200000      'sync at now + 1 sec
      synctime1 := 100000      'sync at now + 1 sec
      routine1_cog := cognew(@lfs_heater,@synctime1) ' Start a Cog with our assembly routine, no stack
             pst.Str(String("Cog Value1: "))
             pst.Dec( routine1_cog)
             pst.Str(String(" ",pst#NL))
   ' is required since PASM requires we explicitly
  '  assign and use memory locations within the Cog/Hub
   ' waitcnt(tm += 80_000)
      synctime2 := 20740
      routine1_cog := cognew(@lfs_heater1,@synctime2) + 1 ' Start a Cog with our assembly routine, no stack
             pst.Str(String("Cog Value2: "))
   ' main loop - repeats forever
    synctime3 := 100000
     routine1_cog := cognew(@lfs_heater2,@synctime3) + 1 ' Start a Cog with our assembly routine, no stack
             pst.Str(String("Cog Value3: "))
      repeat
DAT
        org     0
LFS_heater
                mov  addr,par
                rdlong   _synctime1, addr
                mov     Time,   cnt       ' Prime our timer with the current value of the system counter
                add     Time,   _synctime1       ' Add a minimum delay ( more on this below )
                waitcnt Time, #20     ' Start waiting
                mov     dira, Both_P2_P4_P8_output '   Pin24       ' Set our Pin to an output
                mov     outa,Both_P2_P4_P8_low
                rdlong  Delay,  #0
:keep_checking1
                test      Just_input_pin24,ina   wz          ' test for pin 24
                if_z      call #Off_Signal_Base1
                if_nz     call #On_Signal_Base1
                jmp#:keep_checking1
Off_Signal_Base1
                        add     Time,   Period200us       ' Add a minimum delay ( more on this below )
                        waitcnt Time, #14     ' Start waiting
                        xor outa, Pin2
                        waitcnt       Time,#12
                        xor outa, Pin2
                        waitcnt       Time,#24
                        xor outa, Pin2
                        waitcnt       Time,#24
                        xor outa, Pin2
                        waitcnt       Time,#49
                        xor outa, Pin2
                        waitcnt       Time, #49
                        xor outa, Pin2
                        waitcnt       Time, #24
                        xor outa, Pin2
                        waitcnt       Time, #24
                        xor outa, Pin2
Off_Signal_Base1_ret     ret
On_Signal_Base1
                        waitcnt Time,   #10       ' Start waiting
                        xor outa, Pin2
                        waitcnt       Time,#40
                        xor outa, Pin2
                        waitcnt       Time,#75
                        xor outa, Pin2
                        waitcnt       Time,#50
                        xor outa, Pin2
                        waitcnt       Time,#25
                        xor outa, Pin2
                        waitcnt       Time,#25
                        xor outa, Pin2
On_Signal_Base1_ret     ret
                org   0
LFS_heater1
                mov  addr,par
                rdlong   _synctime2, addr
                add     Time,   _synctime2       ' Add a minimum delay ( more on this below )
                 or      dira,#%1
                rdlong  Delay,  #0
:loop1          xor outa, #%1
                nop
                nop
                nop
                jmp#:loop1
                org     0
LFS_heater2
                mov  addr,par
                rdlong   _synctime3, addr
                add     Time,   _synctime3       ' Add a minimum delay ( more on this below )
                or     dira, Both_P4_output'   Pin24       ' Set our Pin to an output
                or     outa,Both_P4_low
                rdlong  Delay,  #0
:keep_checking2
                test     Just_input_pin26, ina   wz          'test for pin 26
                if_z      call #Off_Signal_Hopper2
                if_nz     call #On_Signal_Hopper2
                jmp#:keep_checking2
Off_Signal_Hopper2
                        xor outa, Pin4
                        waitcnt       Time,#12
                        xor outa, Pin4
                        waitcnt       Time,#24
                        xor outa, Pin4
                        waitcnt       Time,#24
                        xor outa, Pin4
                        waitcnt       Time,#49
                        xor outa, Pin4
                        waitcnt       Time, #49
                        xor outa, Pin4
                        waitcnt       Time, #24
                        xor outa, Pin4
                         waitcnt       Time, #24
                        xor outa, Pin4
Off_Signal_Hopper2_ret   ret
On_Signal_Hopper2        mov     Time,   cnt       ' Prime our timer with the current value of the system counter
                        xor outa, Pin4
                        waitcnt       Time,#40
                        xor outa, Pin4
                        waitcnt       Time,#75
                        xor outa, Pin4
                        waitcnt       Time,#50
                        xor outa, Pin4
                        waitcnt       Time,#25
                        xor outa, Pin4
                        waitcnt       Time,#25
                        xor outa, Pin4
On_Signal_Hopper2_ret   ret
Pin2    long    |< 2     ' Encde PIN to a bit mask
Pin4    long    |< 4     ' Encde PIN to a bit mask
Pin3    long    |< 3     ' Encde PIN to a bit mask
Period200us     long  20000 '  200  us
Input_2_4_Mask  long      %00000000_0001_0100
Just_input_pin24   long   %00000001_00000000_00000000_00000000
Just_input_pin26   long   %00000100_00000000_00000000_00000000
Both_P2_P4_P8_output  long   %00000000_00000000_00000001_00010100
Both_P2_P4_P8_low     long   %00000000_00000000_00000000_00000000
Both_P2_output  long   %00000000_00000000_00000001_00000100
Both_P2_low     long   %00000000_00000000_00000000_00000000
Both_P4_output  long   %00000000_00000000_00000000_00010000
Both_P4_low     long   %00000000_00000000_00000000_00000000
temp1 long 0
Delay           res     1
Time            res     1
_synctime1      res     1
_synctime2      res     1
_synctime3      res     1
addr            res     1
  • Cogs cannot access variables that are in other cog's memories. The Prop tool will compile your code without issuing errors or warnings, but it will not run correctly. Since you put all of your variables at the end, their addresses will correspond to the third cog's memory space. These addresses will not be valid for the other two cogs.
    You should group your variables with the cog code that accesses them. Variables such as addr, Time and Delay should have unique names for each cog so they don't conflict with each other. As an example, use addr, addr1 and addr2 for your three cogs.
  • ElectrodudeElectrodude Posts: 1,621
    edited 2016-05-20 14:13
    "org" tells the compiler where you will be loading some assembly into cogram. You should generally put "org 0" at the beginning of every lump of code that will get loaded into a cog, so that the first instruction after the "org 0" is the one that gets loaded into location 0 of cogram (i.e. you pass a pointer to it to cognew). However, if you do funny tricks like have a cog manually load some code while it's running, you might use "org <something else>", where <something else> is where the code will get loaded into the cog.
    "fit" is entirely optional. It generates a compiler error if the current cog address before the fit exceeds the fit value. It's so you get compiler errors and not mysterious runtime errors when you try using more cogram than there is.
    "res" is like long, but it doesn't take up any hubram, only cogram, to save hubram. When the compiler finds one, it increments its idea of the current cogram address, but not its idea of the current hubram address. As a result, they could contain anything when loaded. Because of how they work, they generally need to go after everything else in a cog. You can, however, put code that will be loaded into a different cog immediately after a "res".
