Maybe someone has already done this but my BeMicroCV-A9 showed up today and my first thought was ... if I could use the DE0 Nano board with it . I haven't tried anything yet but I will have a look at the pin-out's and also have a look at the schematic for the DE0 Nano.
re:We haven't assigned a pinout for it yet and when we do then Chip will do a P2 image for this board as well. If I can find some time today I will go over the pinouts for the edge connector as that is the one I am going to use and also the pin header.
Yes and thanks, I understand that and I'm in no hurry. I was going to try to make an adapter at some point and was just going to explore some optioins.
@ozpropdev
re":The header spacing has a 0.1 inch difference between the Be-Micro board and the DE0-Nano.
that's helpful.
http://forums.parallax.com/discussion/150849/bemicro-cv-fpga-board-for-p2
Yes, I know however, I was commenting that your comment was helpful. LOL
Thanks! for the link
You just need someone crazy enough. I was looking at the possibility of a breakout for all the pins including a ribbon connection for the 2X13 pin header for the A/D and the 2XX GPIO. It will be stupid simple, and if there is enough real estate left over on an ExpressPCB protoboard to mount the headers, and swap the signals around as needed.....
There would be 3 of them.....
Yes, this is a somewhat half-baked idea, I've done NO work on this as of yet.
