So, I seem to have some bad luck or something...
My old A7 P123 board had a major power issue that I eventually fixed myself with hardware hack:
http://forums.parallax.com/discussion/162639/
Was very glad to trade in for A9 board.
This one has worked perfectly ... Until today.
Today, it was acting exactly like my old A7 board did. The power LED (and lots of other LEDS) was blinking on and off every couple seconds.
Just like the A7, it eventually fixed itself. Just wait a few minutes, cycle power, and it's all better.
I have to confess that I haven't used my P123 board for a few weeks now.
My guess is that there is some capacitor that gets discharged very slowly and things won't work right until it gets charged back up.
Anybody else seen this? Is it just me?
Maybe I'm the only one who ignored their P123 board for a long time...
Record low temps here have made it colder than usual at my desk here.
Did a little experiment:
Put P123 in refrigerator for 5 minutes then test --> power led is very dim and flickering like crazy
Put P123 in front of heater for 1 minute then test --> works perfectly.
Any Temperature numbers ?
Most variable parts with Temp, are capacitors - did you check the rails for oscillation ?
The power was cycling on and off very quickly so I'm sure the rails had oscillations...
I'd also guess it is a capacitor that is changing value too much...
Curious to see what evanh sees. Pretty brave to do this on a working board...
What does a scope show on the rails ?
Are they going outside limits, and/or just restarting / hiccup ?
(In case anyone wonders, I have it near an open window. The room is warm, but the air coming in isn't, and I like the nice cool breeze mixing with the heat. That's how it happened)
I haven't seen any issues so far, but am in a mild climate
I suspect that the P123 isn't water proof.
Rayman, I think the switcher resistors are in the same place as before. You might try the same fix as you made last time.
PS: Nice film of condensation on the PCB now ...
Interesting that potatohead saw similar thing with DE2.
I think that board has a similar power supply circuit, maybe that's why.
My board is fine now. I just have to either keep it on or warm it up. Not a big deal.
