Basic movement, ActivityBot keeps "clicking" with slight movement — Parallax Forums
Hello,
I have a question about basic movement of the ActivityBot.
I have put together a small program to have the robot "turn right", pause 2 secs, "turn left", pause 2 secs, and then "turn around".
After each movement completes the robot sits and kind of makes a slight grinding noise as it keeps moving a little.
It looks like it is left with some residual turning that was just completed.
For turning right for example I call
drive_goto(26,-26);
followed by
drive_goto(0,0);
when that didn't work I put a pause in between the two "drive" calls of 250.
when that didn't work I closed with a drive_speed(0,0); wondering if it was differently somehow.
I am wondering how to get it to move and come to a resting stop.
My next question will be how to determine if I have made a 90degree turn? I suppose that is part of the cool challenge.
thank you much
  • whoops, sorry about the "wondering if it was differently somehow".
    I was heading in a direction with that sentence, then changed my mind but my fingers were already way out front.
    I should have done a better job of proof reading the post.
    edited 2016-01-17 05:23
    Welcome to the forum!
    You need to calibrate the servo motors to set the null points. The when you tell it to stop, it should stop and stay stopped.
