PNUT issue with INA? — Parallax Forums
rjo__rjo__ Posts: 2,114
edited 2015-11-17 04:08 in Propeller 2
When I do this it works fine
setb     outa, #25
setb    dira,#25
when I do this it works fine
mov   temp,#0
wrlut ##$FFFFF,temp
mov   inna,##$FFFFF
mov   temp,#0
wrlut inna,temp
BUT not when I do this...
mov   inna,INA
mov   temp,#0
wrlut inna,temp
Gives $FFFF FFFF
Using P123 A7 with fix
I have tried every addressing mode for INA... so that isn't it. So, what is it?
  • What is INA connected to on the hardware side? If none of the pins go anywhere, then $FFFF_FFFF would not be a suprising value to get.
  • rjo__rjo__ Posts: 2,114
    I have two input pins connected to +V3.3 on the header and one output pin connected to an LED... which lights correctly. The rest are floating. The +V source is fine.
    I'm hoping that it is just an issue with my board. But it is weird enough that I thought it was worth mentioning.
    When I look at INB in a similar way... pins 15 and 16 are the only ones that change to zero... even though nothing is hooked up:) V+ to other pins has no effect.
    Do I have to declare pins as inputs? My understanding is "no" and that INB should show the states without any fuss... as on the P1.
    I have serial working fine... using pins 62 and 63. And I have video working fine in the same program.
  • At the beginning of your code, put a WAITX ##25_000_000 and see if that works for you. Several weeks back, there was an issue reading inputs unless a large delay was inserted. I am not aware of a resolution to that issue, so you may be encountering it here.
  • Rich
    INA is working Ok on my P123-A7 board
    All pins tested Ok as inputs (INA 0..31)
    Thanks guys. I did what I was supposed to do.... have a beer and go to bed.
    This morning, I retried everything and get the same. I have to believe that it is the board. Problem is that every other time I have believed this (except once)... it wasn't the board; it was me.
    if I look at #INA, I do get $1FE, so INA is where it is supposed to be;)
  • cgraceycgracey Posts: 14,133
    rjo_, are you still experiencing trouble?
    nope:)
    neglected to pull down my pins. Which is probably the mistake I was also making with my P1V project. BUT I still can't figure out how to rotate (x32,y32) by theta
  • rjo__ wrote: »
    Rich
    Use QVECTOR to convert your x,y values to Ro,theta.
    Use QFRAC to convert angles to 32 bit values.
    and use QROTATE to get back x, y values from a R0,theta pair.
    Something like this:
    		qvector	#50,#50		'x=50,y=50
    		getqx	ro		'ro = $47 = 71
    		getqy	theta		'theta = $20000000 = 45 degrees
    		qfrac	#12,#360	'convert 12 degrees
    		getqx	angle		'angle = $08888888
    		qrotate	ro,angle
    		getqx	new_x		'new_x = $45
    		getqy	new_y		'new_y = $f
    Hope this helps :)
    Brian
    I thought I tried everything:)
    SETQ Y
    QVECTOR X,ANGLE
    SETQ Y
    QROTATE X,ANGLE
    If the SETQ is missing, then 0 is used for Y.
