Interesting CTR effects on piezo
T Chap
Some years back Phil gave me this little gem of code to make a piezo have volume control, using one CTR and it requires a specific duration. The problem this week is that I need the tone to stay on indefinitely if needed for a different application, without locking up the main program.
So I tried an experiment using 2 counters and it works perfectly for an indefinite tone as a volume control.
ctra @ frqa turns the volume down dramatically, and without ctra the volume is maxed. Adjust frqa from 100000 to 10000000 for a range of full on to full off as a volume control.
I just found this kind of interesting and maybe someone uses Piezo's and finds this of use.
PUB beep(pinn, freqq, durr) | period, cycles, frqhi, frqlo, t if ((period := clkfreq / (freqq << 1)) < 4000) return cycles := freqq * durr / 5000 if (voll) frqhi := $10_0000 << (voll #> 0 <# 11) - 1 else frqhi~ frqlo~ frqb~ ctrb := %00110 << 26 | pinn 'dira[pinn]~~ t := cnt repeat cycles waitcnt(t += period) frqb := frqhi waitcnt(t += period) frqb := frqlo 'dira[pinn]~ ctrb~
PUB beepON If Voll > 0 dira[14]~~ frqa := 8000000 ' this higher freq turns the volume down when combined with b frqb := 100000 'sounds like 3-4k tone ctrb := %00100 << 26 | 14 'pinn ctra := %00100 << 26 | 14 'pinn
