program between bluetooth module and the microcontroller parallax propeller 1. — Parallax Forums
hi
I need your help to write a code that will allow me for command my a Minimover 5 (A robot arm) with a bluetooth module.
-The program between bluetooth module and the microcontroller parallax propeller 1.
  • Easy-peasy: Instantiate fullduplexserial at the baud rate your Bluetooth modules use (what the arm should be expecting). You'll need one pin for RX (connects to BT TX pin) and another for TX (connects to BT RX pin). I've done several BT projects with the Propeller.
