Propscope — Parallax Forums
Propscope
Hello I am having trouble with my PropScope.
For some unknown reason I am no longer able to use my PropScope and when I tried to run the PropScope program I get the following messages:
1)No device found.
2)Tip:Verify that your Propeller is connected to this PC with a good USB cable and turned on.
I checked with the condition of the USB cables and they are working properly.
I am not sure if their is a way to check the PropScope itself is internally damaged or not.
I always keep the PropScope in the plastic bag that came with the PropScope kit set to make sure it does not get damaged.
What are the possible solutions to fix this problems?
