$7 Frequency Counter Kit 50MHz
Just do it. A companion to the $20 digital oscilloscope kit we all got.
http://www.ebay.com/itm/Digital-LED-DIY-Sets-1Hz-50MHz-Crystal-Oscillator-Frequency-Counter-Meter-Kits-/231668525889
Prop $6.99
XTAL $1.10
(From Parallax QTY 1)
Puts it over erco's budget.
I have a couple of Hanno's products, Viewport and the PropScope. Shows what the Prop can do.
Of course erco only wants to talk BS1 or BS2.
$16.80 shipped from the US, available from several others, and you can even get them from China if you want.
www.ebay.com/itm/UNI-T-UT136B-Auto-Range-Digital-Multimeter-AC-DC-Frequency-Resistance-Tester-/381277496822
Well, < 50MHz in Freq, and 10ns in dT
Didn't someone mention a Badge with an OLED ?
That could make a good FreqCtr engine ?
Nice, but it says
Frequency 10Hz/100Hz/1kHz/10kHz/100kHz/1MHz/10MHz ±(0.5%+3)
I guess that 0.5% is some RC Osc cal, or maybe a cheap Ceramic Resonator.
Limits the use somewhat ? - ok for ball-park stuff.
https://youtube.com/watch?v=URKSs02qz5c
So the 5 digit counter has special RF uses? Anyway, if more digits = better...
ebay.com/sch/i.html?_nkw=frequency+counter+2.4+GHz+cymometer
Yup, more digits is better
That's a pretty cool unit, as it also says:
Using temperature-compensated voltage controlled crystal oscillator (2.5 ppm VC-TCXO).
only minus, is they did not do a reciprocal counting engine...
Based on Performance/price, that one could even trump the kit in #1.
eevblog.com/forum/projects/ten-dollar-pic-100khz-2-4ghz-frequency-counter/
Looks to be pretty decent, lacking in documentation though. Appears hard to go wrong for the price, but by time you get everything else you need for a finished project, may be just as well to buy one of those <$100 Victor branded units.
http://www.dx.com/p/jy-mcu-16x-digital-tube-yellow-led-module-104311#.VeYt1Pmqqko
No freq ctr, but you could connect this to a Prop.
Now, what to use all those digits for...
Freq and Voltage ? Duty Cycle and period ? Dual Counter ?
Baud value and Character counter ? Cycles and Frequency ?
Oh, Module looks to be no longer available ? A digit too far ?
The TM1640 LED driver seems still available ?
Amazingly it's the first time I ever came across the word "cymometer".
It's hard to resist ordering one of the VFD versions.
The word "cymometer" does not seem to exist in the Oxford dictionary so it's not English
But it is in Webster on line dictionary defined as "An instrument for exhibiting and measuring wave motion". Seems to date back to 1913.
However the word was coined by the Englishman who invented the cymometer in 1904:
J.A. Fleming (University College London), who supervised
the Cornwall end of the famous transatlantic radio
communications of Marconi, is reported to have said:
“… The wavelength of the electric waves sent out from Poldhu
Marconi station in 1901 was not measured because I did not
invent my cymometer or wavemeter until October, 1904..” [4].
Prior to this wavemeters had been developed (e.g. by Dönitz,
German patent date 4th April 1903) and perhaps even
marketed commercially in Germany (for example by
Telefunken – then called Gesellschaft für drahtlose
Telegraphie m.b.H., System Telefunken, founded 1903 in
Berlin)
Fascinating story here:
http://blogs.mhs.ox.ac.uk/innovatingincombat/files/2013/03/ACDavies_wavemeters_Oxford_conference.pdf
Lot's of nice pictures of cymometers or "wave meters" as they are normally known.
"The Application of the Cymometer to the Determination of the Coefficient of Coupling of Oscillation Transformers"
J A Fleming
Proceedings of the Physical Society of London, Volume 19, All articles
http://iopscience.iop.org/article/10.1088/1478-7814/19/1/348/meta
We have stumbled into some great history here.
kymo-, kym-
(Greek: wave, sprout; swollen)
Kind of makes you wonder how the Chinese found this word to describe their frequency counters.
I might guess that the Chinese name for such a thing is descriptive of something that counts waves. And that a literal translation of that becomes "wave counter" hence they come to "Cymometer"
Anybody here speak Chinese?
Now get this: We refer to these things as "Frequency Counters". Which on reflection is totally wrong. They do not count the number of frequencies in a signal!
No, but they do count cycles and give the answer in frequency.
Many of course, can do both Frequency and Counts, so Frequency Counter is entirely correct for those.
CQ CQ de WN4CIK K...
Edit: Blue red or green all $11.88 from same seller. Collect them all! http://www.ebay.com/itm/Blue-0-1-60MHz-20MHz-2-4GHz-RF-Signal-Frequency-Counter-Cymometer-Tester-/181666154685
73 OM
Me too. Had to google it. Wave cycle meter. Guess that makes it the mother of all frequency meters.
http://www.ebay.com/itm/JBT-Instruments-30-FHXX-Reed-Type-Frequency-Meter-New-Surplus-in-Original-Box-/371418683852?hash=item567a4759cc
http://www.ebay.com/itm/181666154685
