Hantek 6022BE and 6022BL questions. — Parallax Forums
I was looking at these 2 units the Hantek 6022BE n 6022BL oscopes, now the BL has a 16 pin logic analyzer n says the inputs for oscope are digital. Does anyone know on the BE? Anything i find just says 2 ch. Analog maybe?? Also are these good units?
Joe
  • The BE Model is two Channel Analog input. Th BL is is two Channel Analog input, with 16 channel digital logic analyzer input.
  • Ok thanks, though on Hantek's sit they say the BL is 2 ch digital input. I have heard that analog and digital units are both similar but analog units will pick up stuff that the digital units might not see.
    Joe
  • RDL2004RDL2004 Posts: 2,554
    edited 2015-08-22 23:05
    Both are digital scopes, the input signals can be anything within the allowable range. It does not seem to be all that good of a value. I would read some of the user reviews posted on the eevblog forums before buying one.
    Paste this in a google search box:
    site:http://www.eevblog.com/forum/ hantek 6022
    Bad forum software, making a link inside a code window!
    Do not click the link, copy and paste the entire line of text into a google search.
    edit: here this should be clickable, I had to remove a lot of google tracking garbage first.
    https://google.com/search?&q=site%3Ahttp%3A%2F%2Fwww.eevblog.com%2Fforum%2F+hantek+6022
  • I am seeing mixed reviews on them, which confuses me about them. I am looking at other options.
    Joe
  • Joe,
    Sorry to confuse you, both oscilloscopes that you referred to are in fact digital o, scopes
    meaning they have digital front ends instead of analog front ends.
    They both accept analog or digital inputs.
    I own a Parallax USB Scope, plus a PropScope, but I am looking at buying a https://www.parallax.com/product/32308
    because it performs as a logic analyser with two analog, (or digital) inputs.
  • I have used a Hantek DSO2100 USB for years without any problems.
    Now I am using a Hantek DSO5102B for about a year and I like it.
    They were cheap was my reason for buying them.
  • I thought of the propscope, just dont have the money for it.
    I saw some video reviews n read some. I see some that say no problems, and others that say the drivers/software dont work, and I dont have much cash so I want something I know wont be an issue.
    Joe
