Accelerometer Noise
ajward
Me again...
I was experimenting with the 3-axis accelerometer to build a very primitive seismometer. Kind of works, but I haven't managed to catch any hiccups on the local faults.
Anyhow, I was wondering... when sitting still on my desk the readings have a =lot= of fluctuation. Not big movements, but quite constant. So, if the unit was mounted on the famous "immoveable object", would it show any fluctuation?
I know sitting on my desk it's going to pick up a lot of vibration. But does the chip generate any sort of internal noise?
That question make any sense?
Appreciate any wisdom y'all can impart.
Amanda
Amanda
Earthquakes have sustained movements, so your software can look for that. Or you might add a second accelerometer of the same type, mounted a few inches away but in the same orientation, and compare the instantaneous outputs of both.
I bet even the best seismic system rely on filters. High sample rate sensor raw data is a beast.
Here are some plots of an LSM303DLHC accelerometer/magnetometer and a L3GD20 gyroscope covering 10 seconds of recording on a concrete sidewalk outside my house.
And if we zoom in on the acceleration:x feature:
So, you can see that this raw sensor has a noise of about +-0.25m/s^2 for ~75% of the time (eyeball).
There's the slightly bigger originals in the attached .zip (the forum has a restriction of 1024px max width).
Geology is one of my many interests and I thought it would be cool to try to catch a jiggle on one of our many faults. Tho' I suspect if I caught a tremor strong enough to be noticeable on the LCD, the LCD might be the least of my concerns. =:-|
