Ws2812 code and terminal not working right. — Parallax Forums
jdoleckijdolecki Posts: 726
edited 2015-04-05 21:36 in Accessories
I making a small light for my robot using the ws2812 leds. I modified the code to change lights and patterns which is selected by the ( int h)
The problem is when I try to run terminal code to change (int H)h the led pattern changes but the light wont flash?
Also is there a simpler way to code this?
  ws2812 Simple Test.c
#include "simpletools.h"                    // Library includes
#include "ws2812.h"
#define LED_PIN     7                       // led chain pin and count
#define LED_COUNT   4
ws2812 *leds;                               // Set up ws2812 instance
int a1[] = { COLOR_RED, COLOR_RED,          // light pattern a persuit
             COLOR_BLUE, COLOR_BLUE };
int a2[] = { COLOR_BLUE, COLOR_BLUE,
             COLOR_RED, COLOR_RED };
int b1[] = { COLOR_YELLOW, COLOR_YELLOW,     //light pattern b caution
             COLOR_YELLOW, COLOR_YELLOW};
int b2[] = { COLOR_BLACK, COLOR_BLACK,
             COLOR_BLACK, COLOR_BLACK };
int c1[] = { COLOR_RED, COLOR_RED,           //light patter c stop
             COLOR_RED, COLOR_RED};
int c2[] = { COLOR_BLACK, COLOR_BLACK,
int d1[] = { COLOR_WHITE, COLOR_WHITE,        //light patter d inspect
             COLOR_WHITE, COLOR_WHITE};
int d2[] = { COLOR_WHITE, COLOR_WHITE,
             COLOR_WHITE, COLOR_WHITE };
void main()
  leds = ws2812b_open();                      // Open leds instance
int time;                                     //blink time delay
int color1;                                   //pattern1
int color2;                                   //pattern2
int i = 0;
int h;
  while(1)
  if (h == 0)
        color1 = (a1);
        color2 = (a2);
        time = (250);
  else if (h == 1)
        color1 = (b1);
        color2 = (b2);
        time = (750);
  else if (h == 2)
        color1 = (c1);
        color2 = (c2);
        time = (500);
  else
        color1 = (d1);
        color2 = (d2);
        time = (750);
    i = (i + 1) % 2;                          //blink count
    if(i == 0)                                // if i is 0
      ws2812_set(leds, LED_PIN,               // Display pattern A
                     color1, LED_COUNT);
    else                                      // Otherwise...
      ws2812_set(leds, LED_PIN,               // Display pattern B
                     color2, LED_COUNT);
    pause(time);                               // blink time delay
