PDF files of single sided SX-28 boards — Parallax Forums
LoopyBytelooseLoopyByteloose Posts: 12,537
edited 2015-02-19 13:50 in General Discussion
Hi all,
Here are three PDF files of Eagle board designs for the SX-28.
All are single sides so that the user can make these at home.
The red is a wire jumper on the top side of the board.
The blue is all the printed circuit on the bottom.
Included are the following...
A. An SX without regulator and two ribbon cable interfaces.
B. An SX with a TO-92 7805 regulator and two ribbon cable interfaces.
C. An Sx without regulator, but with the MCP3208 ADC and three ribbon cable interfaces.
One can easily use headers instead of the ribbon cable interfaces. Power is intended to be limited to low power uses.
All have an SX-key programing interface.
IF YOU LIKE WHAT YOU SEE, YOU CAN USE OR MODIFY FOR YOUR OWN USE IN EAGLE.
I USED VER 7.2XX
    edited 2015-01-30 23:55
    Working on revisons of the about 3 boards to panelize them to fit a 100mm x 150mm circuit board.
    This will allow 6X on the SX28 and SX28 with regulator. And 4X on the SX28 with ADC.
    It really is not worth mixing up chemicals, printing transparencies, and timing exposures for just one board at a time. My goal is to get a good transparency of each and to spend an afternoon printing 3 100mm x 150mm boards -- one of each and keep those on hand.
    edited 2015-02-01 23:49
    Here are 6X images for transparencies for the SX28 and SX28 with regulator (TO-92 LM78L050).
    I still have to create an SX28 with ADC in a 4X image. But these certainly will get anyone easily started.
  • SXleeSXlee Posts: 47
    edited 2015-02-02 05:40
    Think you :-)
    Do you have others for the SX48
    edited 2015-02-02 08:18
    Sorry, nothing created for the SX48 so far. It would be a bit different as the SX-48 only comes in surface mount packages. I one-sided board would have to be only the top layer.
    My main focus was to get ribbon cables to provide a way to connect with breadboards and other boards that are DIY. Is that what you are looking for?
    edited 2015-02-02 12:32
    Oh it's OK :-)
    I have some 28 surface mount ... but I have a lot of 48s.
    edited 2015-02-02 23:53
    Eagle CAD is free in Linux, Windows, and OS X in a demo mode. That is the software I am using.
    http://www.cadsoftusa.com/download-eagle/
    And Eagle CAD provides a library add-on for all the SX chips at their web site for free.
    My situation is that I don't have any SX SMD chips and I am freely sharing what I am developing for personal use. Why not download Eagle and do the same?
    At this point, I am not sure what you want or need.
  • mklrobomklrobo Posts: 420
    edited 2015-02-03 12:51
    Hey, Loopy!
    Good job on your project, there. :)
    I will try out the Eagle CAD. What do
    you use these IC s for in your projects?
    Thanks.
    edited 2015-02-03 17:33
    Thank you for your help :-)
    I'll look in to Eagle CAD.
    edited 2015-02-03 18:23
    mklrobo wrote: »
    Hey, Loopy!
    Thanks.
    Small projects -- just about anything that a BasicStamp does can be done with an SX28 unless you need more program space. Then you might use an SX48.
    They can be programed in SX/B or in SX/ASM
    edited 2015-02-03 23:36
    Please note -- the SX chip library at Eagle is listed at Ubicom.lbr
    Senix-Ubicon was the original manufacturerer of the SX chips. I opened it and it seems to work fine. (Sadly, the Propeller.lbr at Eagle seems to need some work. But that is a separate issue.)
    edited 2015-02-05 03:08
    My primary goal here was to create single-sided boards that could easily be made at home.
    The SX48 and SX52 have 4 pairs of Vdd and Vss that should all be connected with nearby capacitors. It is not really easy to do all this in a single sided board. Two layers would be better.
    My past experience with DIY two layer boards is alignment of the layers when exposing the transparencies is tricky. I am open to others suggestions as I have had little luck with two layers. And of course, there is an added problem of creating vias from the top to bottom layer and through-hole plating. It seems that two or more layers are best ordered from a jobber. You still can design in Eagle and provide Gerber files to jobbers. I have done that in the pass.
    edited 2015-02-06 05:11
    I have created single-sided boards for my SX48 before, I just could not get two layer boards here, ¿I think it was with Eagle? ... I did not know about Ubicom.lbr, thanks for the info!, I think I should get back in to it.
    edited 2015-02-06 06:09
    Sorry It wasn't Eagle it was ExpressPCB that I was using.
    Do you know if there is a Ubicom library for ExpressPCB?
    edited 2015-02-06 07:25
    I am only an Eagle CAD user. I really can't help with libraries in other software.
    You say that you have done single sided SX48 boards before. I would be interested to know how. Did you rely on mostly SMD components or use through-hole components? And how did you manage the Vdd and Vss?
    In Eagle, you can create vias on a single-sided board and later solder in jumper wires.
    edited 2015-02-06 08:05
    SXlee wrote: »
    The standard ExpressPCB Schematic library only has BS1, BS2, and BS2P40 chips. It's very easy to create a new component.
    You might look in the SX forums to see if there was a board made in ExpressPCB. There might be a component made.
    edited 2015-02-06 16:20
    That's OK, it was only IF you had.
    I'm sorry it was a SX28, the SX28 was the only SMD.
    There was one jumper wire.
    Vdd and Vss, I just tied them together.
    989 x 849 - 67K
    779 x 573 - 36K
    edited 2015-02-06 21:03
    Okay, it was an SX28 in SMD.
    I can understand doing that even though the reduction in size begins to get tight.
    My woes are in the power distribution requirments for 4 each of Vdd and Vss. I have considered having the backplane be Vdd and doing something fancy to connect vias that are not plated through holes. The main challenge is to create two layers of transparencies and to manage to align them perfectly during exposure so that the end results are properly aligned.
    It begins to look as though I would have to build a jig of some sort to assure transparency alignment remains tight. Not impossible, but I just haven't considered how I might do so.
    Even without through hole plating, there are advantages to having DIY two layers. The biggest advantage is that boards can be smaller with two layers of wiring.
    Generally, I have avoided SMD projects -- but the world has changed and two-side boards with minimal SMD certainly allow one to use the SX48, the SX52, and the Propeller.
    I print my transparencies on a Hewlett-Packard Deskjet 2000 as the ink is dark enough and sticks to the transparency quite well. I previously tried Canon inkjets and the ink beaded up.
    But be aware that the HP Deskjet transparencies do remain sticky and easy to smudge for quite awhile. I generally generate one and use it once without saving for repeat use.
    One can put print register marks on the transparencies to align multiple layers. The register marks should be at diagonally opposite corners for the best results. The tricks to resolve are how to align while not smudging, and then how does one hold alignment during exposure?
    I have to think more about this.
    edited 2015-02-07 02:14
    If you look closely at Foto-0042.jpg‎ you'll see two big thick traces Vdd and Vss.
    I can only get single-sided and can not get the photo-sensitized board here, so
    I have a brother laser jet and heat-transfer with an iron, touch up with a marker, then etch. and the only SMD I had at the time of making that board (my first board with SMD's) was the SX48 and SX28.
    edited 2015-02-07 10:48
    I am aware of the heat transfer process. I doubt that it would be easy to align on double sided boards. I dislike the heat transfer process as it never worked well for me. I always had to go back over the image with a pen to fill in missing spots. Fortunately, a black permanent market can do that.
    So far, that limits you to SX-20 and SX-28 SMD chips. I will think a bit more about how I might make a single sided SX-48 for iron on, but I suspect it will be a bit large and messy. That seems to be what you really require, and likely what most DIY at home would want anyway. The double-sided solution gets fancy very quickly, and I cannot see doing it with iron on images.
    I have been spending time today on trying to create a double-sided SX-48 board that can be done DIY at home, but have not got Eagle 7.2 to behave well. I am having trouble with the use of vias to reach the second side.
    For printing double-sided boards at home....
    I am pretty sure I can align the top and bottom transparancy, sandwich a cardboard insert to hold the circuit board, and then punch holes through all the layers on the outer edges to retain alignment.
    This woud mean that I would also have to cut a piece of cardboard with a hole the size of the board to be exposed and have it with the same holes in the cardboard around the edges.
    So I guess I would have the three layers together --- top transparency, the board jig, and the bottom transparency -- in proper alignment before I punch holes through all three layers. I might be able to use some plastic screws and nuts to assemble all three layers into a unit.
    Exposure would be one side at a time, but the set up would have the board sandwiched between the two transparencies during the exposure process.
    Of course, this may all need some further refinement. I will continue to think about such. I am waiting to complete a few more images. I have 5 boards here. When I get 5 transparency images, I intend to print the 5 boards on one busy day.
    I did produce a 4X SX-28 with ADC image, and it prints nicely in GIMP software, but when I convert to PDF it changes size. So I have not posted it here yet. I am trying to create all my images in PDF to make creating a transparency or iron-on very easy.... just print and use.
    Individual images are easy in EagleCAD. But I transfer the image over to GIMP to make 4x and 6x images. To do that in EagleCAD you have to buy a licensed copy.
    edited 2015-02-15 23:44
    Hi all,
    I have not been happy with the graphic quality of my 4X and 6X board images. So I had to run down what I was doing wrong.
    I was using GIMP in Linux to take a single PDF image and convert it to a multiple image. GIMP is a pixel graphics editor, similar to Adobe Photoshop. And it is the wrong tool for this job.
    So I switched over to Inkscape in Linux, which is a vector graphics editor and I am getting a much finer finnished image.
    In sum,
    anyone can use Eagle and the .brd images are ready to properly create a single board transparency.
    If you desire 4X or 6X images, you can either wait for me to post new ones here OR you can use Inkscape to create your own from a the Eagle output of single images to PDF. (I simply IMPORT the single image PDF, then COPY and PASTE to a multiple image, and finally EXPORT to a PDF or directly PRINT the .svg file.
    The whole reason for this is to avoid the expense buying an Eagle license that offers a similar feature. I have found that it is more economical to print a whole 100mm x150mm or 110mm x 165mm board than to bother with cutting boards up for individual tiny transparencies.
    edited 2015-02-16 10:59
    Herein is a 6X revision of the SX-28 with regulator PDF. I will try to get more soon.
    I am sure that a comparision with my previous image will demonstrate an improvement IN THE ACTUAL PRINTED IMAGE. This is intended to be used with a 100mm x 150mm blank circuit board to simplify production and reduce wastes of material and time.
    Also, the alignment of all 6 images is spot on. My technical skills have improved.
  • David BetzDavid Betz Posts: 14,511
    edited 2015-02-16 11:09
    Has anyone noticed that the Parallax store no longer has any DIP versions of the SX in stock? And, since it is EOL, they won't be getting any more in either I imagine. End of an era I guess.
    edited 2015-02-16 12:51
    David Betz wrote: »
    Has anyone noticed that the Parallax store no long has any DIP versions of the SX in stock? And, since it is EOL, they won't be getting any more in either I imagine. End of an era I guess.
    I stocked up on 20 or so, so if you need one, (DIP), let me know.
    There are only 2,000 SX28AC left. I guess if I were to put together a product, I might buy 100 at a buck. Almost 100,000 of SX48BD-G.
    I wonder if Robert is still selling These?
    http://forums.parallax.com/showthread.php/94916-SX48-40-pin-DIP-full-kit-and-PCB-available.
  • 4x5n4x5n Posts: 745
    edited 2015-02-16 16:56
    David Betz wrote: »
    Truly the sad end of an era!! I'm glad I stocked up!
    edited 2015-02-17 00:24
    No more SX-28 DIP? I guess I can move on to the SX-28 in surface mount packaging. It just seemed that for DIY one-sided printed circuit boards, the DIP images are more forgiving.
    I have quite a few SX-28 DIPS, that's the reason for working up these images. I also have quite a few SX-18 DIPs.
    Youall may have noticed that I did produce a single-sided DIY image for the SX-48 in a separate thread. It is there to get anyone started that desires. And the more I fiddle with these images, the more I realize that I might do a bit more clean up of that.
  • David BDavid B Posts: 590
    I still dig into my hoard of SX chips and protoboards for small projects every now and then. They are so handy that I'm tempted to buy a handful of SX48 chips for after I'm retired when there'll be time to learn how to solder those tiny little parts.
    So yes, I'd say there'll be a use for SX48 boards.
