The Magic Switchbox
ercoerco Posts: 18,731
A good trick...
And one kid's rambling explanation: https://www.youtube.com/watch?v=JA21m1x8MCI
"When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
- Pablo Picasso
  • 34 Comments sorted by Date Added Votes
  • msrobotsmsrobots Posts: 1,816
    edited January 2015 Vote Up0Vote Down
    This is beautiful, thank you @erco
    Enjoy!
    I am just another Code Monkey.
    A determined coder can write COBOL programs in any language. -- Author unknown.
    Press any key to continue, any other key to quit
    The key words "MUST", "MUST NOT", "REQUIRED", "SHALL", "SHALL NOT", "SHOULD", "SHOULD NOT", "RECOMMENDED", "MAY", and "OPTIONAL" in this post are to be interpreted as described in RFC 2119.
  • ercoerco Posts: 18,731
    Many of these video demos are by Brits. Perhaps the Magic Switchbox was invented by Lucas Electrics.
    - Pablo Picasso
  • Duane DegnDuane Degn Posts: 10,002
    His video painfully reminds me of some of my own.
    There are some fun "magic" LEDs and switches which don't use microcontrollers but they do involve a lot of surgery to the LEDs and switches. They use a combination of inductors, capacitors and resistors to tie the control of individual LEDs with individual switches.
    I gather from the kid explanation, these magic switch boards require some skill from the performer to remember with lights come on when. The surgically modified LEDs and switches don't require any practice to operate. I'll try to find a link.
    Don't be mean. It looks like Lucas even sold wire harnesses to Mercedes Benz.
    I do have one (or two) of them problem child's. 1993 500SL and 1995 SL500. Both have a problem with 'biodegradable insulation'. Yes. The insulation of the wires in the 3 main engine harnesses is destroying itself overtime. Them engines run smooth so you do not have any problems until you MOVE the wire harness. Then you get shorts and destroy expensive electronic modules, not (or too expensive) to buy for a 20+ year old car.
    I cut (carefully) the top harness open on the 1993 500SL and you see blank wires hold apart by small pieces of insulation left. The rest of the insulation is crumbled away.
    And this is on a German 'Super Car', top line of Mercedes Benz, sold for ~$120,000.- Sticker Price in 1993.
    As far as I know, MB used them biodegradable harnesses from 1993 to 1995. Great. So both of mine are affected.
    Enjoy!
  • Heater.Heater. Posts: 20,220
    erco,
    Lucas might have tried but as I recall it was a bit of a lottery as to which switch operated which device at any given time in a car with Lucas electrics.
    When it rained all the hazard and brake lights would come on by themselves. Which was just as well because the engine would have cut out due to shorted HT anyway leaving you dead in the middle of the road.
    No joke, this happened to me. Happy days...
    Here's one without a case and I don't think it relies on any tricks from the performer.
    http://hackaday.com/2011/12/19/ask-hackaday-troll-physics-edition/
  • davejamesdavejames Posts: 3,894
    ...and one kid's rambling explanation...
    THAT was friggin' painful. Couldn't finish watching.
    Well-written documentation requires no explanation.
  • ElectrodudeElectrodude Posts: 1,146
    Duane Degn wrote: »
    He uses his iron to transfer the solder. His circuits never work as expected because of how bad his soldering skills are.
  • tomcrawfordtomcrawford Posts: 825
    + 100
    Re-inventing the wheel is not a waste of time if, when you are done, you understand why it is round.
    Cool, CA, USA 95614
  • kwinnkwinn Posts: 7,712
    davejames wrote: »
    Same here. Can't help but wonder who they think they're impressing.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • DomanikDomanik Posts: 233
    A good trick...
    Yes, the kid's rambling was a little rough, but, heck, it eventually led to some interesting disclosures.
    In case you missed it, the solution uses half-logic levels as seen here:....Half-Logic
    <br>
  • LawsonLawson Posts: 870
    Wow, some tricky thinking went into making that circuit! First bit, this is obviously a circuit with a lot of concealed components. Power comes from an induction coil under the table or a concealed battery while the batteries in the tray are just decoys. The switch caps have some electrical components in them. I'd love to see the switch caps and modified switches up close! Similarly, the lamps have a good bit of extra circuitry added to them. After reading the "Troll Physics" comments on Hackaday I'd guess it's based on AC currents and filters. I could also see doing it with a bunch of 1-wire tags, a microprocessor, and tiny wires hidden inside the insulation of the visible wires.
    Marty
    micro-power experiments with the propeller.
    Drivers for TAOS TSL3301 line sensor Forum thread, and OBEX
    Lumen Electronic Jewelery Website
    My AWD motorcycle Website and action video
    What I'm paid to work on. UW Lidar Group.
    FME, a Spin-only floating point library with trig, exponential, and logarithm functions. OBEX and Forum.
    Lawson wrote: »
    Do you mean the little colored bits on the tip of the switches? I think they're just the normal switch caps. The person switching the switches knows which lights come on in which order. Much of the trick is just memorizing which lights will light when.
    The "Troll Physics" circuit relies on clever electronics the one with colored caps on the switches is just a performance trick. At least that's what the rambling kid said. That and he likes Radio Shack.
  • xanaduxanadu Posts: 3,139
    I love this stuff!!
    This thread reminds me of this http://forums.parallax.com/showthread.php/142040-LED-stuck-ON
    I started making another one.
    [video=youtube_share;Nx6gvN-NW4o]
    As you can see in my video I use simple point to point wiring as well.
  • Peter JakackiPeter Jakacki Posts: 6,822
    xanadu wrote: »
    I love this stuff!!
    I can squeeze three little insulated wires (vero wire) in the red insulation too. The solder connection to the black can be clearly seen but the red connection tucks out of sight with the insulation still in place.
    Tachyon Forth - compact, fast, forthwright and interactive
    Tachyon Forth News Blog
    TACHYON DEMONSTRATOR
    Brisbane, Australia
    Nice one :) I'm pretty sure that has a lot to do with the wiring in the first video.
  • GordonMcCombGordonMcComb Posts: 3,224
    I am preferring to believe it's all done with Magic Electrons.
    I believe. I believe. I believe. I believe. I believe ...
  • TorTor Posts: 1,868
    But all electrons are Magic Electrons.. the way I see it, electricity is magic in the Real World. If you came from a reality with no electrons (I know, I know..) and was reading fantasy books about magic, nothing would really compete with what electrons can do.
    -Tor
    It is all ledgerdomain, same thing at Microsoft.
    Some people want to know, others just want to believe. (Trust me on this...)
    Hwang Xian Shen, Puddleby-on-the-Marsh.
    All things considered, I can live and thrive without Microsoft products. LINUX is just fine.
  • davefrtdavefrt Posts: 8
    edited August 2015 Vote Up0Vote Down
    Hello all... i m new here...
    And l see that....
    Face....
    961460front.jpg.
    This is the switchbox and fuse 2015 new idea....
  • Is there a video?
    wait i make the video tomorrow...
    but i like it to,because just pieces of plastic moove....
    with more détails...
    this is video:
    tell me what you think about it new 2015 switchbox and fuse .....
    Very nice! Never gets old!
    Welcome to the forum :)
  • Thanks so much...
  • Love it! Nice job.
    - Pablo Picasso
  • have you find the real secret....
  • Yes, I did some searching and found the preferred method. I'm not sure how they used this method in the clear cases, but it was less extravagant than I had imagined so maybe there is another way. The method I read about uses switches you can't see, and they don't need to be flipped with your fingers.
