Digole Display Driver — Parallax Forums
Michel LMichel L Posts: 141
edited 2014-07-25 05:29 in Propeller 1
I'm working on my first driver object that I plan to publish on the OBEX.
First a small question: Does the spin compile remove PUB methods that are not used? I think it does, but I'm not sure.
As I've put in the title, it'll be a driver object for a display from Digole
The display I have: 1.8" Color OLED160x128 (the manual)
I 'm planning to put most of the Arduino methods in my driver.
So far I've just been creating the methods and putting some transmit commands in them. With the strings inline
OBJ
  display      : "Simple_Serial"
PUB init(displayPin): Okay
  return display.init(-1, displayPin, 9600)
PUB initBaud(displayPin, baud): Okay
  return display.init(-1, displayPin, baud)
PUB sendCommand(command)
  display.str(command)
PUB clearScreen
  sendCommand(string("CL"))
PUB enableCursor
  setCursor(1)
PUB setCursor(cursor)
  sendCommand(string("CS"))
  display.tx(cursor)
PUB disableCursor
  setCursor(0)
PUB printString(text)
  sendCommand(string("TT"))
  sendCommand(text)
Is this the best way to go? Or should I put the control characters in the CON or DAT section?
Any help is appreciated. I don't know exactly what the best practices are with the Prop.
Michel
  • Michel -
    Did you ever post anything to obex for this display? I can't find any reference to a Digole display driver.
    I just bought a 320x240 display that uses the same protocol and I'd rather not spend time (re)creating an object if you already have something that I could use.
    Walter
  • I just wrote a driver for it including clickable buttons (touch screen), numeric keypad overlay, etc, it's not really complete but it does what I needed. I'll try to get it posted here this week-end.
