P2 counters question — Parallax Forums
Bill HenningBill Henning Posts: 6,445
edited 2014-03-21 12:23 in Propeller 2
I know the docs are not finished...
Is it possible to do the following with the new counters:
- set initial output state (0 or 1)
- toggle the pin every N clocks (where N = 1...x in clkfreq's)
- limit the toggling to a specified COUNT
ie
generate 8 pulses at 100MHz (assuming 200MHz cpu clock) on pin X
generate 32 pulses at 100Mhz (assuming 200Mhz cpu clock) on pin X
generate 256 pulses at 100Mhz
do the above, but with differential pin pair output
--- If not possible ---
Are the counter instructions deterministic enough that we can start a count with the initial state we want, perform two instructions per count, and stop the counter... and we would be guaranteed not get any extra pulses?
  • cgraceycgracey Posts: 14,133
    edited 2014-03-20 22:08
    ie
    That's a neat idea - and it would take way less than what makes up a CTR to realize.
    edited 2014-03-20 22:13
    Thanks!
    I would REALLY appreciate it if this made it in.
    It would make various clocked bit-banged protocols much easier and faster.
    It would make fast nibble-banged QSPI easy :)
    And it would make a good generic clocking mechanism for the internal SERDES clock (another use for it)
    cgracey wrote: »
    edited 2014-03-20 22:18
    And if N=0, output the system clock (or its inverse, based on stated start value)
    Also, COUNT would be the number of times to toggle; so an odd count would leave the output in the opposite state it started from
    Initial=0,N=1,COUNT=15
    (logic level output)
    01010101010101010101
    toggled 15 times, output starts at 0, ends in a 1
    Initial=0,N=1,COUNT=16
    010101010101010101010
    I came up with this while thinking of how to do fast SPI and QSPI before SERDES and potential 4 bit XFER
    By providing the initial pin state, we can generate rising edge triggered and falling edge triggered clocks
    Same counter mode would also work well as the P2 generated SPI master clock for SERDES
    Could also be used for slow XFER's (for LCD's, QSPI, etc)
    Heck, it could be an instruction...
    CLOCKFRQ #/divider ' 0=clkfreq, 1..511=divider
    followed by
    CLOCKGEN pin, #/count, #0|1 initial state ' maybe count=0 means infinite count, initiates background clock pulses
  • TubularTubular Posts: 4,621
    edited 2014-03-20 22:24
    Another way to do it might be to have a 'stop if PHSx is exactly zero' mode, set when configuring the CTR initially.
    It would then be up to the user to seed the FRQx and PHSx registers to get the desired number of pulses at any frequency they like.
    Could be useful for sine bursts too, though I think Chip included a rollover instruction to aid this
    edited 2014-03-20 22:35
    I am sure the counters could be put to better use with a few variations, like used to clock the SERDES in or out, as well as outputting this clock. Inversion permits I2C and other protocols where the clock edge is in the middle of the bit.
    Hopefully this is on the table together with SERDES. I think the SERDES has way more uses than just serial.
  • jmgjmg Posts: 15,144
    edited 2014-03-21 02:12
    That would probably need an extra control register per timer (maybe an extra one is there already for True PWM modes ?)
    If not, an alternative would be to have one timer gated by the MSB of other, which would be clocked by the First timer Overflow.
    One timer would set the Count and one would set the /N ?
    edited 2014-03-21 02:24
    I'll add a timer feature detail request, since this is a Timers thread.
    For a pair of Counter/Timers :
    * Ability to have Atomic control of capture of both Timer values, from pin Edge.
    plus
    * Ability to Clock from SysCLK, or a Pin Edge
    In use you then have a simple loop of either
    Loop1
       Wait Some Gate Time
       Disable both captures on same clock (atomic)
       Read capture Registers.
       Enable both captures on same clock (atomic)
       GOTO Loop1
    Loop2
       Wait Some Gate Time
       PollForCapture
       Disable both captures on same clock(atomic)
       GOTO Loop2
    Loop1 rounds-down, and Loop2 is round-up, to nearest whole cycle dN and dT values.
    From there, a reciprocal counter is simple SW.
    This Atomic topology loses no edge information, and can run multiple precision counters.
    With no lost edges, a background total can sum dN and dT for higher precision, longer update results.
    Logic cost of this should be very small, it may just need some flag-aliases.
    Just reading another thread, and it occurs that this feature would allow simple SW (even the Monitor?) to generate a wide range of accurate pulses.
    The SW + Serial link says when to start, and the pulse is managed in HW, after the regs are set.
    If the Monitor can R/W any register (Which I guess is standard) then this becomes easy.
