Prop2 Counter module modes — Parallax Forums
ozpropdevozpropdev Posts: 2,791
edited 2013-05-18 10:20 in Propeller 2
Hi Guys. Is there any information on the Prop2 counter module modes?
Details such as quadrature encoder mode etc...
Sifting my way through all the new instructions...very excited !!
Cheers
P.S. Nice work Chip & Beau...
  • cgraceycgracey Posts: 14,133
    edited 2013-05-15 07:49
    The CTR's are the last big thing to document. I'll be working on that in the coming two weeks.
  • TubularTubular Posts: 4,621
    edited 2013-05-15 17:35
    Since you're local OzPropDev...
    Chip kindly sent us a spare DE0 breakout board - so let me know if you want to play to get a head start on the physical silicon.
    I don't currently have a spare DE0, but they aren't that expensive. I hope to do a short presentation in the next month or two, using the DE0 and DE2
    regards
    Lachlan
  • ozpropdevozpropdev Posts: 2,791
    edited 2013-05-15 17:36
    Excellent!
    Thanks Chip
    edited 2013-05-15 17:41
    Thanks Lachlan
    I was ordering a DE0 board today so that would be great!
    Regards
    Brian
    edited 2013-05-15 19:17
    ozpropdev: Great to see another Ozzie getting onboard the P2.
    edited 2013-05-15 21:38
    PM me your address and I'll get it on its way
    Also... when your DE0 comes in, don't forget to put a jumper across pins 3 & 5 of the 26 pin header on the back of the module, to enable the PLL video. Its buried in some documents and drivers but easily forgotten.
    edited 2013-05-16 21:26
    Its in the post, you should see it Monday.
    You'll need the Altera Quartus Programmer (just the programmer part saves you downloading the entire bloated package)... if you get stuck let us know
    edited 2013-05-16 22:20
    ozprodev: see the "sticky" thread for info on getting your DE0 runing
    edited 2013-05-16 22:56
    Thanks Guys for your help.
    Looking forward to getting stuck into Prop2.
    Cheers
  • potatoheadpotatohead Posts: 10,253
    You will have fun. It's a real playground. The very first thing you can do is get setup and run the monitor for a quick check, poke around a little and then it's off to PASM!
    See my blog for an intro document and some setup help. That one doesn't cover the add on boards yet, but it's good otherwise.
